Side Panel Logos / Badges / Tank Badges Restoration
  • Shuriken
    • 1093
    • Southwest USA
    Beautiful. Too bad I don't have a standard.
    1985 Yamaha VMX12n "Max X" - Stock
    Formerly:
    1982 XS650
    1980 XS1100g
    1979 XS1100sf
    1978 XS1100e donor
    • Shuriken
      • 1093
      • Southwest USA
      I had no idea the badge replicas were die-cast material instead of plastic. I ordered a set and they are pretty nice quality.
      Ben
      Formerly:
      1982 XS650
      1980 XS1100g
      1979 XS1100sf
      1978 XS1100e donor
      • randy
        • Dec 2003
        • 4521
        Ben, watch out for the hole spacing, i had to tap one new hole in each tank flange to fit the badges. They are fairly hefty in weight, so i woudn't use double-sided tape as they suggest.
        their disclaimer:
        BadgeReplicas badges are cast from a casting metal, harder than alloy but still slightly flexible. All metal badges are chromed or gold plated, and painted with two-pack enamels or automotive lacquers. These cast metal badges are just slightly smaller than the factory (OEM) badges (due to 1% - 2% shrinkage during cooling of the cast metal). While this is not at all noticeable visually, it does sometimes require that the badges are mounted with other techniques, such as automotive double-sided tape. This ensures a more secure ‘fix’ in any case – you may have noticed that virtually all modern automotive badges are affixed with such tape!
        • Shuriken
          • 1093
          • Southwest USA
          Yeah. I figured out when straight, they align well. When I bent them into a slight curve, it was harder to mount them. I have a little friction on the factory holes and am using the factory clips on the underside.
          I didn't know I could get the 79sf side panel badges in chrome. I only see gold on their site. I would rather have had chrome.
          Ben
          Formerly:
          1982 XS650
          1980 XS1100g
          1979 XS1100sf
          1978 XS1100e donor
          • DVigue
            • Aug 2007
            • 52
            • Sparks, NV
            Re: Have you looked at these sites?
            Originally posted by cajun31
            and Mikes XS has tank badges. [/B]
            Anyone know if the gold ones at the top of this page http://www.mikesxs.net/mikesxs-acces...ategory_id=8.2
            will fit an XJ1100J? If so, I am all over them to replace my as they are a bit "old" looking.
            1982 XJ1100J "Horse with No Name"
              Sorry,
              But they are not the same, mounting hole or size, they are smaller than the XS/XJ 11's. However, folks have reported using double sided tape or other attachment techniques.
              IIRC, folks have stated that the emblems used for the Yamaha Golf Carts ARE the same size as the XS/XJ11's, and much cheaper.
              • Lamric
                XStremely XSive(Deceased)
                • 410
                • Kenley, Surrey, England
                I've not used them myself, but these are the Yamaha golf cart emblems - Part number JN6-F4161-01-00
                Brian
                • Shuriken
                  • 1093
                  • Southwest USA
                  Yamaha badge restoration kit
                  Formerly:
                  1982 XS650
                  1980 XS1100g
                  1979 XS1100sf
                  1978 XS1100e donor
                  • DJinNH
                    • Mar 2008
                    • 854
                    • New Hampshire
                    Originally posted by ae7f
                    Thanks for that!
                    Ben
                    I went to your link and ordered a set for my XS1100SG, both tank and battery covers. (Badge Replicas in Australia).
                    I just got them today. The tank emblems are plastic and look really good on my freshly painted tank. The battery cover emblems are metal and solid. They look great too.
                    I've very happy with them but they weren't exactly cheap at $200 for the set....but it was worth it, I feel.
                    Thanks for the tip/link. I'll be ordering a second set for my other bike now that I know they are quality and arrive fast.
                    Don
                    currently own;
                    1980 Yamaha XS1100 SG
                    2009 Yamaha Star Raider
                      How much?
                      Hi Don,
                      $200? That's about the price of a set of good tires and you spent it on steenkin' badges? And I thought myself a spendthrift for buying a set of aftermarket stick-on 3TF tank badges at $6 each.
                      • DJinNH
                        • Mar 2008
                        • 854
                        • New Hampshire
                        Re: How much?
                        Hi Don,
                        I know, I know. Once I got into restoring these bikes, I guess I went a little nuts in wanting everything the way they were 28 years ago.
                        Don
                        currently own;
                        • Shuriken
                          • 1093
                          • Southwest USA
                          Formerly:
                          1982 XS650
                          1980 XS1100g
                          1979 XS1100sf
                          1978 XS1100e donor
