I too have an electrical query
  • Mortman22
    • Jun 2006
    • 51
    • Ballston Spa NY
    My brake lights won't work. I took of the cover for the bulbs, or lamps, and both filliments of both bulbs are on all the time. That doesn't seem right to me. Shouldn't only one set of filliments be on when the brake isn't being applied. any help would be great. thanks
    Jake
    82 XJ1100 "Slave One"
    • 5061
    Re: I too have an electrical query
    That is right, Jake. The tail light should have marker lights come on automaically when the engine runs, and the brighter filiments are for brake indicators.
      Remove the seat, and disconnect the brake light wire. It's yellow I think. See if it goes out. If not, then possibly the filiment has broken and fallen on top of the tail light filament. If the brake does go out, check for a stuck brake light switch on either master cylinder. There will be power on the yellow wire if that is the case.
        • 5061
        Oh sorry, I just saw that you have an XJ and I know NIL about it!
        • Mortman22
          • Jun 2006
          • 51
          • Ballston Spa NY
          hey thanks John
          Jake
          • Hammerhead1st
            XStremely XSive(Deceased)
            • Jul 2007
            • 330
            • Lawrencvile, GA
            AHEM...
            LOL, was removing my footpeg mounts to polish them up and accidentally bent the switch spring retainer while removing. Didn't realize what I had done until everything was assembled and I took off for a job interview behind schedule. Someone else let me know the brake light was on all the time. Got to my interview and saw what was wrong, bent it back, everything worked out great.
            SOOO
            As mentioned earlier, I would check the master cylinder switches for a stuck switch
            "Rat Rod"
            79 XS1100 Standard
            87 VMAX cans
            Cheap Japanese Tires
            Cobalt Blue Rattle Can Paint
            Custom Lighting on a Budget
            Perry Center Fire Department
            Perry Emergency Ambulance
            "If we don't do it, who will?"
            Some people have one of those days, I have one of those lives...
