O.k. guy's I need your help got the starter installed changed the gas in the gas tank replaced the octopus,battery,solenoid,tci, changed the plugs. havent changed the fuseblock yet but will work on it.
at first it only started with starter fluid figured out that one of my fuel lines was to long and kinked (i had replaced a couple of lines)
took the tank of and fixed that issue now it started but I cant keep it running I did put some sea foam in the gas tank.
I will work in the oil next but I have not been able to get it on the center stand and need to install the fuseblock got one of those sealed battery so I have power. Also tried to take the master cylynder apart but did not do to good I am thinking the little plastic thing on the pump may be off and the plastic end that i can see looks rotted.
Once I get it running will need tires.
ok I am not to mechanically inclined so all your help will be appreciated I am trying to stay away from the carbs for fear of messing them up more then they may already be.
Thanks
Tonio
Thanks
Tonio
