setting carbs on a xs11 oo specil
  • brownbear1000
    • May 2007
    • 83
    • Bay View wisconsin
    How do i ajest the carbs on a xs1100special cleaned them as good as i can took them all apart thay hade like glue it them the bicke will start at an idol but you have to pump the throttel veary light till it worms up them it will take off like something is still blocking the gas then it will idol but ruffyou give it gas run it about 4 grand let it idol shut it off and it is veary hard to start let it cool and it will go agen
    help
  • mro
    • 4276
    • Hayward, California
    carby questions
    What year are the carbs?
    Some differences between 78/79 and later carbs
    ________
    Are the carbs really clean?
    Followed the tech tips here ???>>>http://www.xs11.com/forum/forumdispl...?s=&forumid=30
    Iinformation regarding stock carb cleaning, float height, pre-synk, vacuum sync, pilot needle adjustment etc.. will be found in the above link. When this has been done and you are still having problems post em agin.
    mro
    • mro
      • 4276
      little more help
      order in which I tackel the carbs
      remove and clean
      Replace float needle/seat if needed
      Identify and write down jet sizes (I need a magnifying glass to read em)
      Set piolt screws to 1 1/2 turns out
      Set float height
      Double check float height (check both sides of each float are even)
      Bench sync (can use a thin wire as a feeler gauge to get butter fly valves close)
      Bench test for leaking (hook up a fuel supply to check float valve(needle) does not leak.
      Check that petcocks are not leaking and have good flow when on or run posistion.
      Check fuel and vac hose condition.
      Check intake boot condition.
      Check throttle cable.
      Slide carb behind cylinders and hook up throttle cable.
      Reinstall the carbs (stick em the boots), attach fuel/vacuum hoses
      Hook up filter box etc..
      Place fan blowing on front of motor.
      start motor.
      Adjust idle (main idle screw)
      Vac sync carbs
      Adjust pilot screws
      Re-synk carbs
      Test run time
      mro
      btw, complete job which includes some minor engine cleaning made easy while the carbs are off takes about four hours
