80or81 XS1100 SG/SH Hand Crank
  • geneborg
    • May 2007
    • 74
    • Tampa, FL
    I recently purchase the two above bikes and hope to make one runner out of them. How do I go about hand cranking the engine's over in that they no longer have the access to the crank mechanism?
    gene borg
  • mro
    • Oct 2005
    • 4276
    • Hayward, California
    XS Hand Job
    Pull left round engine cover
    Inside will find a square nut which you use to turn engine over.
    Good or checking valve clearence, checking/setting pointer to TDC as well as adjust cam chain tensioner.
    mro
    • RUSH
      • Feb 2005
      • 214
      • Lake Stevens, WA
      remove the left engine case cover and use an open end wrench to turn the crank in the direction of the arrow
      First bike was an: 1978 XS1100
      Second bike is an FJR1300.
      Now I'm restoring a '79 XS1100.
      • mro
        • Oct 2005
        • 4276
        BTW
        Check your serial number against post at left under "Specifications" then Serial Numbers.
        Will identify which model you have.
        mro
        btw2....welcome to XS Land
        • confish04
          • Dec 2006
          • 52
          • Lancaster PA
          Re: 80or81 XS1100 SG/SH Hand Crank
          gene borg
          You can always put bike on center stand , take spark plugs out & put bike in gear & just turn the rear tire. Or take cover off & turn with wrench , but remember take the plugs out or it`ll fight you all the way.
          Gerard
          04 Roadstar (starglide)
          80 midnight special
