I recently purchase the two above bikes and hope to make one runner out of them. How do I go about hand cranking the engine's over in that they no longer have the access to the crank mechanism?
gene borg
Pull left round engine cover
Inside will find a square nut which you use to turn engine over.
Good or checking valve clearence, checking/setting pointer to TDC as well as adjust cam chain tensioner.
Originally posted by geneborg I recently purchase the two above bikes and hope to make one runner out of them. How do I go about hand cranking the engine's over in that they no longer have the access to the crank mechanism?
gene borg
You can always put bike on center stand , take spark plugs out & put bike in gear & just turn the rear tire. Or take cover off & turn with wrench , but remember take the plugs out or it`ll fight you all the way.
