Signal light
  • Ljay40
    • Jun 2006
    • 149
    Signal light
    It seems my right side signal light will not flash unless I have the rpm about 2 grand However the left side works great
    and when I use the emergency flashers all the lights will flash properly with the bike not running.
    I have check all grounds die electric grease on all connections
    I guess the confusing part is the emergency flashers work flawlessy with the bike not running could this be a diffrent circuit
    I have even changed to a diffrent set of signal lights that came with the trunk I bought same thing
    any ideas ? Wimpy reg/rect why would there be diffrence in each side..
    Im baffled
  • mro
    • 4276
    • Hayward, California
    emergency flashers use seprate flasher.
    While wimpy grounds seem to be a common cause of "no flash syndrom" , can also be corrosion on the "hot" side of circut as well as corrosion inside the light socket.
    mro
    btw, turns should flash with out engine running, and since one side seems to work other side is pointing to a fault in the wireing or light socket.
