today's ride was...eventful!
  • renegade_xs11g
    • 462
    • Mid-Michigan
    just went ri
    My Photo Bucket
  • renegade_xs11g
    • 462
    • Mid-Michigan
    OOPS
    just went for a little ride
    one of my pipes fell off
    IT FELL THE F@$% OFF!
    no big deal, just THIS morning a guy I work with GAVE me the mufflers
    off his '07 SOFTAIL.
    but then...it gets worse!
    Didn't hook up the charger like I normally do, on thursday. (Stuck out of town)
    Made a couple of stops along the way. and then the battery went dead enuf'
    to make me have ta' bump start it, MAN THAT SUCKED!
    Picture if you will... stopped at a light, bike stalls (MONSTER has a few bad habits, not tame yet! )
    SWMBO is on the back. I'm ROWING with my feet (can't describe it
    My Photo Bucket
    • renegade_xs11g
      • 462
      • Mid-Michigan
      doggone it!
      anyhow I am gonna clean harness.
      where will I find the connectors and what should the reading be
      using an ohm meter for testing
      thanks for all the help so far
      PRICELESS
      My Photo Bucket
      • mro
        • 4276
        • Hayward, California
        Bad battery?,
        or poor connections?
        there are three white electrical connections behind fuse box which have noticed that they seem to get over looked.
        several in head light bucket
        couple left side under fuel tank
        a few other connectors here and there
        as well as grounds to frame
        When clean and making good contact
        bike at idle, battery should have just over 12V
        2500 rpm over 14V
        no big deal, just THIS morning a guy I work with GAVE me the mufflers off his '07 SOFTAIL.
        Harley parts are known to do that
        Also reason Harley riders like to have a pasenger(someone to push there bike
        mro
          • 5058
          Re: doggone it!
          If you have a weak battery, it will fall on its face at a light. Sometimes disconnecting the headlight fuse can help get you home once you get it started again as long as you don't burn the brake lights too long at slow idle.
          • renegade_xs11g
            • 462
            • Mid-Michigan
            Was having computer problems last night
            got ticked off and shut it off.
            my battery is new, I charge it just to be sure I don't have days like that, precautionary only
            the harley mufflers ain't on yet,
            the pipe that full off was just a straight piece of pipe, no baffles or anything,
            3 white wires, OK Thanks
            Wouldn't own a HARLEY if you paid me!
            Rode on the back of a Sportster, once 35 mile trip, Last year,
            MY BACK STILL HURTS!
            Genltemen, as always, thanks for the Help
            John
            My Photo Bucket
            • mro
              • 4276
              my battery is new,
              Got a "bad" new battery last year.
              Seemed to take the initial charge just fine.
              Installed and everything worked fine for two days then not enough power to start. Got a jump start so rode back to shop, recharged battery and load tested.
              Took it back and got another........
              mro
              • mro
                • 4276
                Sportster
                My old XLCH was pretty comphy but never rode on the back.
                Did vibrate a bit tho.
                mro
                • renegade_xs11g
                  • 462
                  • Mid-Michigan
                  bad parts outta the box...
                  always a possibility, one I have had in the past, but still look at last for some reason.
                  Just went to change oil in the car, IT"S RAINING.
                  Gotta do that before I can work on monster, swmbo said so.
                  No garage,
                  My Photo Bucket
