Hi All,
Finally got the 78E on the road, really happy,
except, now when I shut Her down, then go to
crank up again, it it like dragging real bad.
Crank, clunk, crank, clunk, etc.. Soooo pulled the
starter today, and get some really goofy digital
ohm meter reading:
Oh, My meter is on the 200 ohm scale, & with the
probes connected, I get .5 ohms .
So, here is what I get, which do not seem good to Me.
cable con. to case: 58.7 ohms
cable con. to 1st brush: 54.1 ohms
cable con. to 2nd brush: .6 ohms
1st brush to case: .6 ohms
2nd brush to case: 54.1 ohms
ok, now the armature.
between all the bars: .5 ohms
bars & shaft mounting: infinity
Length of both brushes: 11.1 mm
So, is the starter shot, or what, &
what should the readings be ?
Thanks, in advance,
Andy B.
ohm meter reading:
Thanks, in advance,
Andy B.
