Need Help!!!!!!!!
    Frmrby,
    Try looking for a vacuum leak. My guess is that a backfire blew off a cap, and #3 has a leak. That would also account for the fast idle. As far as the sudden quit, check to be sure the "kill" switch isn't off by a little bit. On my machine, just a few degrees will make the engine stop.
    • frmrby69
      • May 2007
      • 35
      • Michigan
      #62
      Well I can't seem to find any leaks any wear. When this motor is cool it idles low but as soon as it gets to a good operating temp it only will idle down if I rev it up. My question is if the carbs are not synch perfect will this cause this problem?
      The plugs all look good except number 2. It does have a slight whiteness to it. It is not real bad but maybe a touch lean. I guess I need to make a vacuum tester and test the vacuum on each carb. The other thing is that I am not sure that the vacuum lines were hooked up correctly when I got the bike. The line that comes from the vacuum advance line is plugged into the optopus and there is a short jumper line the goes from the carb to the same cylinder intake boot. I just found in another post that this is backwards and this could be causing some of my problems, I am going out to change this and see if things straighten out. I also took apart all the electrical connections and cleaned all of them to see if I have any further problems with the bike stalling.
      Work In Progess is an under statement!
      Frmrby
      1980 XS1100SG Work In Progress
        Throttle cable
        May be a stupid question but have you checked and lubed the throttle cable?
        • frmrby69
          • May 2007
          • 35
          • Michigan
          #64
          No I have not lubed the throttle cable but the cable seems to be fine. I changed the vacuum hoses around so they are on correctly at it helped some and now the octopus works like it is supposed to. I need to check the vacuum line from the vacuum advance to see if I am getting good vacuum. I also turned down the idle some. It will not idle cold but as soon as it gets warm it wants to idle at around 2000 rpm. I am going to turn it down some more in the morning before I leave for work and see if it is just set to high.
          It seems that it is just a fact of getting all the little bugs worked out. The bike runs really well but just every now and then gives me a fit. I guess that is what you get for running a bike that is 27 years old. But I do love to ride it and it is one of the funnest bikes I have ever owned.
          Frmrby
          • Ken Talbot
            • 4251
            • Revelstoke, BC
            #65
            Non-sync'd carbs will cause you all sorts of problems. Build one if you have to, but I would really recommend spending a few bucks and buying even the cheapest set of mercury sticks. You will use them over and over again once you have them.
            Ken Talbot
            • frmrby69
              • May 2007
              • 35
              • Michigan
              #66
              Just wanted to drop a line to all that helped me get my ride running.
              I have been riding almost everyday for the past month. It runs perfect and rides like a rocket.
              I can't thank all who helped enough.
              HATS OFF!!!!!!!!!!!!!!!!!!!!!
              Frmrby
