Need some help
  • Radiation
    • Jun 2006
    • 90
    • Eugene, Oregon
    Need some help
    Hi again. I put a new exhaust system(MAC 4-2) on and noticed a popping on deceleration on the left side out of the pipe. I thought it was an exhaust leak, so I replaced the gaskets on that side. No change. I started messing with my pilots. I noticed that on my #2 carb I can close the pilot all the way off with no difference in idle. If I open it up to much, it starts popping during idle. (too much fuel?) If I close any of the other pilots it almost dies. I took my carbs off and completely disassembled and cleaned and blew out. When I put it back together, it did the exact same thing. I am worried the the popping on deceleration is going to burn my valves. Help me guys, I am missing out on riding weather.
    Bill
    1980 XS 1100 Special
    1979 650 Special - sold (Stupid Me!)
    I don't think you have ALL of the pilot passages clean. I would also check on the float levels, and the condition of the "O" ring on the needle valve for the float. I don't think the "new" carbs break the pilot needles like the older style did.
    A little bit of backfire or popping shouldn't hurt, so you can ride it. I know my bike "burbles" on de-acceleration, but I still get 42 MPG and it runs well.
    Just my $0.02
    • Radiation
      • Jun 2006
      • 90
      • Eugene, Oregon
      The o-rings appear to be in good shape. I swapped the needles around with the same outcome. I have my floats set for 25 mm, and they all match. When I cleaned it, I thought I got everything. It was doing it before I pulled them. That was why I pulled them this time. I had carb cleaner spraying out orifices I didn't know I had! I guess I will pull them again this weekend.
      Bill
      • mro
        • Oct 2005
        • 4276
        • Hayward, California
        80SG float height 23mm, + - .05mm
        (from factory manual)
        mro
        • Radiation
          • Jun 2006
          • 90
          • Eugene, Oregon
          23mm from where?
          When I check my float height, I go from the metal lip where the gasket would normally sit to the flat suface area of the float. Is this right?
          Bill
            Hey Bill,
            Yes, from the flat recessed surface that the gasket sits on to the top/highest point of the float.
            Like DiverRay said, the aftermarket pipes do flow a bit better than the oems, and could be leaning it out a little, and with your floats set to high(upside down), it's even leaner. Resetting the floats lower/richer will help, but may not completely eliminate the popping. My 4-1 pops quite a bit during decel when I close the butterflies, and I,too, have new good exhaust header gaskets. I just consider it Godzilla's GROWL!!
            • mro
              • Oct 2005
              • 4276
              If whay your saying is that you have the carbs up-side down on the bench, bowls off and are measuring from the float bowl gasket surface (not from the gasket) then yes.......
              mro
              • mro
                • Oct 2005
                • 4276
                TC speed typer
                think I go mow my weeds
                mro
                  • 5073
                  Re: 23mm from where?
                  You are no talking about that raised line in the center of the metal gasket surface are you? I measure from either side of that raised line, but not from on top of it.
                  • Radiation
                    • Jun 2006
                    • 90
                    • Eugene, Oregon
                    Thats what I meant. I put the end of the calipers on the inside of the little ridge.
                    Bill
                    • Lamric
                      XStremely XSive(Deceased)
                      • 410
                      • Kenley, Surrey, England
                      Brian
