i bought a transmision off ebay. mechanic took trans. apart and can't get {he called it} the secondary shaft out without taking engine out of the bike. he don't want to do that. any body have any ideas? he can't get the lock washer off. its the shaft that holds it in gear.its been worn down and has an 1/2 inch play so trans won't stay in gear.
my mechanic needs help.
Re: i forgot
There is a thread called "750 Final Drive enigma " that has a middle and final drive manual. It should help.
Originally posted by looser182
the bike is an 82 xj 1100 maximSkids (Sid Hansen)
Down to one 1978 E. Stock air box with K&N filter, 81H pipes and carbs, 8500 feet elevation.Comment
thanks
thanks for the link.but it doesn't help. the shaft he is talking about is inside the transmissin gears. we are replacing the 2nd gear, it was popping out, and i guesse the person b4 me held it in second gear and wore down the shift forks and whatever shaft they were touching. that is the shaft that needs replaced. he says because it is wore down about a 1/4" on both sides it moves and bike won't stay in gear. he mainly works on honda's but his sign said bikes 85' and older. i can give anybody his number and you can call him and he can tell you better. thanksa.d.c.Comment
Tranny
Try this
Just go to the repair forum and theres lots of info there ,hope this helps
DougLast edited by mitch; 05-23-2007, 05:58 PM.Doug Mitchell
82 XJ1100 sold
2007 Stratoliner 1900 sold
47 years riding and still learning, does that make me a slow learner?Comment
Hey Looser,
This Link is one of several with nice pictures that show how to remove the counter shaft WITHOUT splitting the cases or removing the engine from the frame, just have to remove the clutch over, clutch, gear shift cover, and 3 torx screws...they are locktited so make sure he has a good fitting bit!!
T.C.T. C. Gresham
thank you all for your help.
i thank you all. just got the bike a few months ago for$375.dollars. the second gear was slipping,tank needed painted,and a new seat cover. i bought it had to ride it 40 miles home and i wrecked it on the turn to my house. it slipped out of gear. anyway, i had to replace the stator cover and stator off a '79, replaced the handle bars,and need a new speedo and tac. got a complete '79 trans off ebay for $45, mechanic said he would put it in my bike for $350 and clean the carbs. but he has run into this problem and need someone with more experince to help. thank you all againa.d.c.Comment
