middle gear
  • rman
    • 228
    • Stroudsbug PA
    middle gear
    Hello,
    I need to change the gear oil in my 1979 XS1100, I want to know what viscosity oil to use. What is called out for by the book? I have havoline 90w and 85W-140. Are either of these acceptable for the middle gear?
    From the Havoline web site.
    "Havoline Gear Oils are recommended for use in all spiral bevel and hypoid differentials, power dividers, and oillubricated steering axle wheel bearings."
    Trying not to offend since Aug 28, 2010
    Disclaimer: I am an idiot. Pay no attention to the man behind the curtain.
    Owner of:
    1979 XS1100F (The Pig)
    140 mains
    45 pilot jets
    Floats at 24mm
    Running Rich
    "Arrogant, delusional tyrants can't be stopped by earnest words and furrowed brows. Action, strong bold action coming from a position of strength and determination, is the only effective deterrent." -Mitt Romney
  • mro
    • Oct 2005
    • 4276
    • Hayward, California
    Recommended, SAE 80 or 90 API GL-4 Hypoid gear Oil
    80/90 GL-4 Hypoid gear Oil can be usd for all condictions
    mro
      Also... MAKE SURE you can loosen the top fill hole BEFORE you drain the oil out! It gets pretty stuck over time...
      • rman
        • 228
        • Stroudsbug PA
        good advice
        Yep, already got this same good advice from randy, I broke an allen wrench trying to open the filler hole already but have since gotten it open.
        The havoline 90w gear oil says that it is GL-5 compliant. I am not sure if this makes it compatable or not?
        Owner of:
        140 mains
        45 pilot jets
        Floats at 24mm
        Running Rich
        • mro
          • Oct 2005
          • 4276
          GL-4, GL-5, GL-6 are quality and additive rating
          All can be used if hypoid gear oil
          mro
          • EZMoney
            • Oct 2006
            • 115
            • Castlegar, BC,
            Don't strip out the filler plug!!!
            If it is tight as mine was ( and probably everyone elses) try with the allen wrench and a pair or long nosed visegrips lightly gripping the top of the plug. turn both together and it should break free.
            It's way easier to clean up the marks on the outside of the plug than to start looking for a new one
            Just my $0.02
            Ed
            78/82 XS/XJ mostly made up of parts bikes
            XS1100 SG 1980 Will restore to original over time
