Rear Tire 78 xs11 sf
  • gotink27
    • May 2007
    • 6
    • tennessee
    i currently have a 120/90-16 on the rear of my bike. does anyone know what the largest tire is i can put on it
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
      • 7795
      The SF is a 1979 model . The E is the 1978, and was only a standard.
        Hey Ink,
        As Mason said, the 140, but with some clarification. This should be a black wall, not raised white lettering. I have a Dunlop 140/90-16 on mine, but it was the RWL, and they rubbed on the left side. I'm still running it, but will be sure to get a regular blackwall next time! Also, different tire brands will have slightly different fitting characteristics, so to be safe, a 130/90 is the stock size listed for the specials....IIRC!
        • gotink27
          • May 2007
          • 6
          • tennessee
          Thanks for the answers. i wound up putting a 130 on it just to make sure i had all the clearance i needed. the biks says 78 but the title says 79 i guess i goofed when i said it was a 78.
          • Meatloaf
            • Jun 2006
            • 116
            Important to get the year right. The E's ran tubeless.
            • newc4
              • 642
              • Vienna VA
              78E tubed tires
              Correction: You meant to say the 78E ran with tubed tires - I just had mine done. Unless you have tubeless rims from a later bike.
              Darrell
              Darrell
              78E
              80G project
              06FJR
              • gotink27
                • May 2007
                • 6
                • tennessee
                My motor is a 79 xs1100sf. i can see, now that i started nickel and dimeing, how different the efgh's can be from the sf sg and sh's. i guess i'm on to the front end now to get the brakes right. i just got a good lesson on syncing my carbs whoo hoo that was fun. thanks for the help
                • Meatloaf
                  • Jun 2006
                  • 116
                  Yep, meant to say tubeless, keyboard-chair interface problem. I think Merriam Cycle claims to be able to put tubeless on the 78s with a little bit of work, no rim change necessary.
                  Did someone say "only" a standard?
                  • Ljay40
                    • Jun 2006
                    • 149
                    My 80 special just put tires on to my surprise its running a tube up front and tubless on the rear.
                    Mechanic even look it up on the microfiche and shows the same tube on front tubless on rear who woulda thought.
                      • 5069
                      Re: Rear Tire 78 xs11 sf
                      If it makes you feel any better, the sf was a 79, not a 78. (No specials in 78)
                      OOPs. Diver Ray caught that one already. nevermind
                      • TADracer
                        • May 2006
                        • 1417
                        • Kenner, Louisiana USA
                        To confirm you have a 79 special look on the motor plate right above the clutch housing for the serial number and also on the VIN tag on the frame up by the left side of the steering head . A 79 special scerial number will start with 3H3.
                        A 79 special is supposed to run tubeless tires both front and rear with a minimum H rating.
                        Have fun!
                        Mike Giroir
                        79 XS-1100 Special
