Valve adjustment is driving me crazy
Read a post the other day about where the peak of the lobe must be to take gap readings- perpendicular to shim and same angle as valve stem. Well I rotated engine until the above description was true and took a reading. Then I jogged the rotation, while sliding the feeler gage in and out. To my amazement the gage got looser and looser until the lobe was about 40 degrees off angle to the valve center line. The next valve was dead on inline with the valve stem. Which gap reading should I use?
Several valves are at different angles to the center line when widest gap is read! My readings using the widest readings gotten are as follows.Exhaust #1 0.2, #2 0.2, #3 0.18, #4 0.215. Intake #1 0.14, #2 0.18, #3 0.15, #4 0.15. From perpendicular reading to widest reading there is as much as 0.03mm difference.
#2 intake shim was removed and was a 265 shim, what do I replace it with?
NOTE: Took spark plugs out then screwed back in two threads, very loose, let me rotate engine and no dirt or other debris can inter the chamber, worked well.
I have four shims to swap with anyone for the ones I need. (2)260's, (1)265. (1)280.
Several valves are at different angles to the center line when widest gap is read! My readings using the widest readings gotten are as follows.Exhaust #1 0.2, #2 0.2, #3 0.18, #4 0.215. Intake #1 0.14, #2 0.18, #3 0.15, #4 0.15. From perpendicular reading to widest reading there is as much as 0.03mm difference.#2 intake shim was removed and was a 265 shim, what do I replace it with?
As usual there is a lot of support here and it is appreciated very much.
I will check the cam dimensions tonight. HobbyMan I will check out the oil and remeasure all, remove all shims from exhaust side, document sizes. Will let you all know results and shims needed. Again THANKS
How is that again guru's. What and how is the best way for me to take readings?
