brake lines question
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    what would most likely be the best fit for lenght for rear brake hose replacement on my 1979 xs1100 standard model.
    From a KZ1000
    From a GPZ 1100
    Yam 750 special
    Thanks
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
  • mro
    • 4276
    • Hayward, California
    hoser replacement
    May be a dumb question, but
    why would you want an old/used brake hose?
    mro
    • 79XS11F
      • 3563
      it's to see if SS brake lines from these other bikes can be used without too much trouble.
      Rob
      1978 XS500E
      1981 Suzuki GS1100
      • Snow
        • Oct 2002
        • 1041
        • Tallahassee, FL
        If you want to keep the splitter and use the stock routing, just measure the hose lengths (preferably off the bike). I've got a set of hoses at my brother's house that I'll measure if I can remember this weekend.
        After that, just order the Russell pieces individually and remember to get new crush washers.
        • 79XS11F
          • 3563
          Thanks snow but this is for the rear. There is no splitter at the rear
          Rob
          1978 XS500E
          1981 Suzuki GS1100
          • Snow
            • Oct 2002
            • 1041
            • Tallahassee, FL
            Ahh, ok - I didn't even think about that as I only did my fronts...figured since either 2/3 or 3/4 of stopping power is front that rear would be alright...well...that and I rode for a couple years without a rear :/
              This may help you
                Hey Rob,
                I put an SS line on my rear brake. The OEM has that funky metal section in the middle of the line, a real PITA! I just took a piece of string, or flexible tape measure and measured the length. Was able to use the clip that holds the metal portion as a holder for the SS line, worked and fitted just fine! I've posted a photo before, but don't remember exactly right now!
                • 79XS11F
                  • 3563
                  Well given that these lines were on e-bay and pretty cheap I got a 3 line set for the front that was listed as being for a 1977 xs1100 ???? They were under $100 and I took a chance on a 750 special rear line being close enough in length to fit. It was under $60 and all are new. I am guessing that the 750 and 1100 rear lines are pretty close in length. I hope I'm right.
                  Thanks for input guys
                  Rob
                  1978 XS500E
                  1981 Suzuki GS1100
