So trusting......
    So trusting......
    My battery is getting bad, but I was trying to get it to make it to the end of the month. I was at work and it cranked a few times.. then clicked. I pushed it over to my work truck to jump start it, (No, the truck wasn't running) when a buddy came out and said "Let me help". So... long story short (Pun intended)... what happenes to the electronics when someone crosses the wires for you? Did it direct short the battery and finish killing it... or did I fry the TCI? I'll check the battery voltage... I am hoping it just shorted it out somehow. Wishfull thinking?
    I will check more on it tonight.. I got it trailered home at lunch. None of the fuses are blown. Even with the battery hooked up to it right, I get absolutely nothing when I turn the key. I feel stupid that I trusted someone to not screw something that simple up, when the consequences can be so great.
  • webbcraft2150
    • Sep 2002
    • 1605
    • AUSTIN.TX
    Did ya check the 30 amp main fuse under the LEFT cover? When it goes, you stop.
      I don't have any fuses under my left cover... a little bit different setup I guess.
      • audijunky
        • Apr 2006
        • 707
        • VA
        I have done this before(yes I a dumb) but all it did was blow a fuse. Have you tried to start it yet with jumpers(hooked up correctly) You(he) may have just cut that batteries last leg off.
        I would try and jump it since you say none of the fuses are bad.
        JM2C good luck
        PS dont other people suck
        79 XS1100 modified standard
        straight pipe 4-2 exhaust
        Owned 83 Honda V65 Magna
        Owned 02 Vstar 650 classic
        owned 85 Honda Shadow VT 700C
          That's what I was saying here. We tried hooking it up right and jump it... and nothing.
          • audijunky
            • Apr 2006
            • 707
            • VA
            Then double check your fuses if you haven't, use an ohm meter to make sure. If they are good .. then I don't know what to tell ya. Haven't had to look past the fuses. I sometimes when jumping would get nothing cause where I connected the black lead to the frame it wasnt a good spot. No ground. Did you hook the cables up to the battery(in the bike) or straight to the leads for the battery in the bike?
              I just went and checked the battery and all the fuses. There's 11.8 volts in the battery and all the fuses check out good. I opened up the TCI and none of the soldered points look burnt or had gotten hot, but I didn't pull the card out to look at the other side of it. I don't see a 30 amp fuse anywhere on this bike... am I missing it somewhere? The biggest one I see is a 20 amp.
              When I tried jumping it, I had the negative cable on the kickstarter shaft and the pos on the battery.
              • audijunky
                • Apr 2006
                • 707
                • VA
                I am gonna sound like an a-- hole no matter how I ask this but are both the key and kill switch in the right positon.
                Does your tail light come on when the key is turned on. I don' t know, I am just writing what I would be doing/checking
                • audijunky
                  • Apr 2006
                  • 707
                  • VA
                  Did you notice a burnt rubber/plastic smell around the fuse block?
                  And how long was it hooked up wrong?
                  • mitch
                    • Oct 2002
                    • 934
                    • fredericton new brunswick canada
                    30 aMP
                    uNDER YOUR SEAT THERE IS A RED LARGER WIRE IT HAS THE MAIN FUSE IN IT, JUST BEHIND THE BATTERY FOLLOW THE LARGE RED WIRE AND YOU SHOULD FIND IT GOOD LUCK
                    DOUG
                    Doug Mitchell
                    82 XJ1100 sold
                    2007 Stratoliner 1900 sold
                    • mitch
                      • Oct 2002
                      • 934
                      Caps
                      Sorry about the caps didnt see them till i posted
                      Doug
                      Doug Mitchell
                      82 XJ1100 sold
                        Yeah... after I posted, I got my book out and started looking for it. It just looks like another electrical box or compnent. The main fuse was blown. I will run to town and see if I can find a replacement. This one looks a little more involved to transfer over to a buss fuse. It looks shorter than a regular glass car fuse... hope I can find one.
                        • Dragonrider
                          • 1219
                          • Garland, Texas
                          That one has gotten MANY riders....You can buy an inline spade-type fuse holder at the auto parts store...but I transferred mine into the (new) fuse box.
                          CUAgain,
                          Daniel Meyer
                          Author. Adventurer. Electrician.
                          Find out why...It's About the Ride.
                            I went to the auto store and got another one... came home and went to install it and saw another fuse in there. I was thinking "Oh crap, I only bought one". Then I saw it was just a spare I guess they put there from the factory? Wasted trip, but at least I know there's a spare there.
                            Thanks for the help everyone.
                            • livelifenowff
                              • May 2007
                              • 41
                              • Des Moines, Iowa
                              thank God that safeguard exists. or thank Yamaha. I'd say your parking lot buddy owes you a cold one.
                              Kyle
                              Four wheels move the body. Two wheels move the soul.
                              1979 XS1100 SF (Nickeled)
                              1983 Porsche 944 (Dimed)(KIA: Rollover)
