Attila!
  • Dan Hodges
    Sensei of Internal Combustion
    • Sep 2004
    • 526
    • A garage in south St.Louis
    Re: Hi Dan
    Originally posted by mro
    It's been post here or on the UK site that "sling shot" carbs/pod filters on a stock XS has giving em 10+ HP.
    So is this just so much smoke............ Where is the rpm point in which they achieved the increase? Pod filters will give you a slight increase with modified stock carburetors in still air if you can get them jetted correctly but the carburetors on an XS are not like those on a sport bike,they are in the open air and exposed too lots of turbulance and the consequences thereof. A motor will only pump so much air and that is based on it's volumetric effiency and consequently unless I saw the results on an independent A to B dyno test I would be suspect of this claim. A 10 horsepower gain on a 95 horse motor is over a 10% gain which is a sh-t load of power for just bolting on a set of carbs.Let me put it like this,if I could put a set of carburetors on my bike that would fetch a 10% gain from 6000 rpm up with no losses on the bottom, I would have already had them on there no matter what they cost. Also if this were true, Vance & Hines,Dale Walker and the rest would be selling these things like hot cakes.
    mro
    BTW
    most XSelent tech you provide
    Been pasting it into my XS log
      the FJ used double throttle cables like an XJ
      The XJ just has a single cable also.
      This is from another thread I posted, but the question still stands. The XJ uses carbs with a 54mm bell versus the XS with a 52mm. Can the XJ carbs theoretically make more power if tuned right, or are the carbs all the same diameter at the point of the slides?
      I have also seen on another post where it seemed you were against pod filters, but now it seems like you are endorsing them a bit... or is it just for the 36mm carbs?
      I haven't personally seen their work, but I know they are big in racing. I have wanted to lighten and knife-edge the crank on mine also. APE racing at www.aperaceparts.com looks like it has the knowledge and a decent price to get that done. I was told that I'd be better off spending the money in other places on the motor than that though.. shaved head, better pistons and rods etc.... More bang for the buck they say. ????
      • Dan Hodges
        • Sep 2004
        • 526
        Last Part Too Modify
        The bell size might make a difference but if it did it would be minute, however the venturis are 30 mm on all these XS/XJ carburetors and the throttle bores are 34 mm.I am saying that the stock air box would be very restrictive with 36 mm carburetors so you would either have to do some serious cutting/drilling of the stock airbox or put K&N pod filters on it.I mentioned the light weight reciprocating parts in passing as that would be one of the last things you would do to this or any other engine.
        Tod [/B][/QUOTE]
        • pggg
          • 1609
          • NZ
          A good set of carbs gives a power boost, transforms the whole bike
          • AlanB
            • Oct 2006
            • 705
            • Scotland
            Hi Guys,
            It is me who has the Suzuki Slingshots on my XS11; The modern carbs give increases in the midrange 'cos they are simply a better design than the older type CVs fitted to the XS. They are also far easier to tune. They can also help top-end for the reasons you can see in the pics earlier in the thred.
            My SG (along with other XSs dynoed at the shop!) gave around 75 brake at the tyre. After fitting and jetting the slingshots, dual-out K&Ns and straight-through pipes, along with some work on petcocks and tank breathers, we got 95 bhp; all corrected for temp and pressure effects.
            Unfortunately, the Dyno charts have been up on my shop wall for years, and are too faded to scan.
            The shop did a lot of work replacing '80s CV carbs with more modern carbs (especially these slingshots!) and always expected similar results; GSX 11s and late Zs really like 'em!
            More info CLICK HERE
            AlanB
            If it ain't broke, modify it!
