ok, i am so close to having everything back together....The regular fuel lines are all connected, thanks to everyones help. the bike accually started last night! i only let it run for a minute then shut it off. about 30 seconds after it was shut off, gas started dripping out of the bottom of the air box, from that little nipple. i guess my first question is, is there supposed to be a hose that is clamped onto that nipple and run straight down as a vent, or does the hose need to be hooked somewhere else? second question would be, why is there so much fuel going into the air box....what did i do wrong? last, and stupidest question of all would be....when i was looking at the nipple on the air box, i noticed that there is a line.....i wish i could explain this better.....a line that is hooked up just below the air box, that i never disconnected from one point. anybody but me would probebly be able to say what part it is cnnected to, my best description is that it "part of the engine just below the air box". The hose that is connected there is fairly long, maybe 1.5 of 2 feet.....no idea at all where it needs to be. So other than those problems everything is great.....help.....
Thank you all again, you have helped more then you will ever know.
-Joe
-Joe
We have all been there and done that
