front end alignment
  • cloerts
    • Mar 2007
    • 153
    • Tahlequah, OK
    front end alignment
    after I dropped frank, the handlebars are 3 inches to the left when the bike is going straight. how do I fix it?
    Casey
    1980 xs1100g "Frankenstein" (Now with a mind of his own!)
    "What do you mean I can't park this thing here?"
    "Shiny side up? I don't have a shiny side."
  • 79XS11F
    • Jul 2006
    • 3563
    • Ottawa, Ont. Canada
    I'm not sure what you mean by 3 inches off to the left but if your lucky they just moved over to the left in the handle bar clamps or the bars are bent?
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • acof911
      • Jun 2005
      • 244
      • S.E PA
      Bummer, that happened to my first xs when some lady backed into my front end in a parking lot and took off.
      My guess - the fork tubes are twisted in the triple tree clamps.
      • cloerts
        • Mar 2007
        • 153
        • Tahlequah, OK
        straight
        when the bike is traveling in a straight line the bars are slighlty turned. at first I thought I had bent the bars, but the triple tree is also turned. I don't think the forks are bent as they still function properly. seems like something was knocked out of position when the bike fell, but I'm not sure what to adjust. It drives fine, no wobble even at 80mph. The bars are just always slightly turned.
        Casey
        • acof911
          • Jun 2005
          • 244
          • S.E PA
          I would try putting it up on the center stand and sticking a wood block or similar under the engine just big enough to get the weight off the front tire. Loosen the upper and lower triple tree clamps that secure the fork legs. Loosen the upper triple tree nut and pinch bolt. Face the headlight and hold the front wheel stationary between your legs while you gently twist the handlebars to straighten things out. Retighten the the fork leg clamps etc. and you (hopefully) will be good to go.
          I have done this before w/ some success.
          Good luck,
          Andy
          • Pat Kelly
            • 3046
            • Golden Valley, AZ
            Good luck,
            Andy
            Also loosen the fender and axle pinch bolt along with the fork brace (if applicable).
            Pat Kelly
            <p-lkelly@sbcglobal.net>
            1978 XS1100E (The Force)
            1980 XS1100LG (The Dark Side)
            1999 Suburban (The Ship)
            1994 Dodge Spirit (Son #1)
            1968 F100 (Valentine)
            • acof911
              • Jun 2005
              • 244
              • S.E PA
              Oh yea, I forgot about those. My fault for attempting pre-coffee thought in the morning...
              Thanks Pat.
              Andy
              • goldcoastguy001
                • Dec 2006
                • 137
                • Gold Coast, Australia
                Yep i agree with what Pat and Aco said.......works every time.....Cheers
                1982 XS1100R
                1982 XJ650
                1983 VT400
                1990 XVS Shadow
                1983 Z1100
                -I just love the look on their faces when you leave them standing in the dust after they've lined you up on your XS.
