Crap, I dropped it!
  • cloerts
    • Mar 2007
    • 153
    • Tahlequah, OK
    Crap, I dropped it!
    I dropped the bike today. Was swapping out for new handlebars, grips and mirrors. I had everything put back together and was strarting it up for a test ride when the clutch handle slipped and the bike took off without me. It didn't hurt any of us, but it did knock of couple of bricks out of the side of the house. Now inexplicabley, the engine is idleing at 4k rpm and the idle adjusment screw does not change it. Any ideas why?
    Casey
    1980 xs1100g "Frankenstein" (Now with a mind of his own!)
    "What do you mean I can't park this thing here?"
    "Shiny side up? I don't have a shiny side."
  • JWSanders
    • 879
    • White House, TN
    Sorry to hear about your spill. Good thing no one was hurt!
    You sure it wasn't idling that high before the bar swap? If they're too tall it could be pulling the throttle cable tighter. Could also be a possible bind from the knock.
    Maybe knocked it out of sync?
    I'm sure the real gurus will chime in, too.
    80 XS1100SG
    81 XS400SH
    Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
    A Few Animations I've Made
    • 79XS11F
      • 3563
      • Ottawa, Ont. Canada
      Bummer about the drop. If the bike took out a few bricks on the house just what part of the bike made contact?
      I also would check the cable and throttle grip. Perhaps the throttle is not returning fully to the idle position if the throttle side grip was damaged. Or as was already pointed out the cable is in need of some adjustment after changing the bars and the high idle has nothing to do with the drop.
      Rob
      KEEP THE RUBBER SIDE DOWN
      1978 XS1100E Modified
      1978 XS500E
      1979 XS1100F Restored
      1981 Suzuki GS1100
      1983 Suzuki GS750S Katana
      1983 Honda CB900 Custom
      • prometheus578
        XS-XJ Super Guru (RESIGNED)
        • Aug 2004
        • 4012
        • Olympia , Wa.
        It's still mad at you, and will probably try to run away from home again.
        I agree... you have a cable problem. Does the throttle still move easily?
        • cloerts
          • Mar 2007
          • 153
          • Tahlequah, OK
          The throttle does not move as easily as it should, I think maybe your right and I need to adjust the cable for the lower bars. contact with the house took place at the left turn signal, engine cover, and mirror. left turn signal is demolished, engine cover has a groove, and the mirror is scratched. also the lower bars made contact with the tank( hadn't even had a chance to adjust those yet) and put in a small dent and chipped a quarter sized piece of paint off. My easy project just got a lot harder.
          Casey
          • cloerts
            • Mar 2007
            • 153
            • Tahlequah, OK
            also I have some good dupont paint at home, is there anyone near NW arkansas that would be willing to teach me how to paint? since I chipped the tank it seems like a good time to learn.
            Casey
              It's not teachable
              Casey asks:-
              Hi Casey,
              it's like riding a bicycle, no one can teach you, you have to learn. Get yourself the gear, compressor, paint gun etc (fizzbombs are garbage) and practice on stuff you don't care about. Fiddle with various paint/solvent ratios and different air pressures. 80% of good paint is the prep work. Those solvents ain't healthy neither, get a good breathing mask.
              Fred Hill, S'toon.
              • cloerts
                • Mar 2007
                • 153
                • Tahlequah, OK
                turn signal
                ok so I need a left turn signal to get back on the road, anybody have suggestions of to but or not buy them?
                Casey
                • prometheus578
                  • Aug 2004
                  • 4012
                  • Olympia , Wa.
                  There is no such thing as an easy project.
                  • xsscooters
                    • Jan 2007
                    • 114
                    • Ft Smith Arkansas
                    NW Ar
                    Where are you at in Ar i live by Ft Smith ..
                    • renegade_xs11g
                      • 462
                      • Mid-Michigan
                      new turn signals
                      sorry about the drop.
                      Did it my self 2 years ago, but I dropped it @ 45 MPH. OUCH!
                      I saw the lights thru a link on this site...
                      parts n more I think
                      they were 10 bucks each, NEW!
                      good luck, John
                      My Photo Bucket
                      • Kurt
                        • Dec 2006
                        • 248
                        • Denver, Colorado
                        Check and make sure that the cable housing is still in all of its little grometts too. Could be that simple.
                        "It is better to die on your feet, than live on your knees."
                          Painting
                          Pay particular attention to the mix ratio between the paint and reducer. That is the key and pick a high quality clear coat to finish that is compatible with the paint.
                          Practice on something and do a search on the web for spraying techniques. It is really not that difficult. You don't want to spray to light or too heavy. The first causes a dry sandy coat and of course the second might run. You want overlapping strokes. Don't try to finish it in one or two coats. Build it up slowly.
                          You will get it.
                          • cloerts
                            • Mar 2007
                            • 153
                            • Tahlequah, OK
                            Re: NW Ar
                            prairie grove, near fayetteville.
                            Casey
