fuse block
    That single fuse holder is what is referred to in the Clymer manual's wiring diagram as the terminal assembly. It is a circuit for add on electrical components, separate from the fuse panel, and won't interfere with the swapping fuse boxes.
    • HobbyMan
      MeatHead Idiot "GURU"
      • 1801
      • Colleyville, TX
      I still don't have a photo yet. Sorry
      Acta Non Verba
        Hey Dodjh,
        I ran the Positive that normaly went to the fuse there with the terminal screws up and over to the fuse block, then ran another line from the other side of the fuse block to the terminal connector. The ground is just run like it is to ground. So...just bypass the glass fuse holder clips and run it thru one of the fuseblock slots!
