Hi. I got my forks apart and have been trying to get the seals out now for a couple weeks now. Give up, then go back
. Anyway, I have a 79sf with air/oil forks. I see the thick rubber thing in there. I tried a seal puller with no luck. Today I got my dremel and started cutting at the darn thing, then using a screw driver to pry on the metal. After a while I finally got the seal out as a mangled mess. But then I looked and saw that there seems to be an inner ring seal behind the first. And I scratched up the seal surface a bit too. How on earth do these come out? And is there two parts or what. Very frusturated. Thanks for any help.
