Well, clutch isn't slipping....BUT...now it's running weird
  • renegade_xs11g
    • 462
    • Mid-Michigan
    Thanks for the advice on the slipping clutch, it was just an adjustment
    I had to take an air filter off and hold my hade over the mouth of the carb to get it to start.
    I know, I know.
    That's not the answer.
    Still no time to rebuild those carbs.
    In process of replacing a wheel bearing on the car,
    I had to chase after a bearing puller, for the car
    plus it was a very nice day. & I didn't want to drive the FREIGHTLINER
    any way, I can't tell if it's an intermittant miss, or intermittant fire.
    seems to be around 3000 rpm
    motor is very cold blooded, it takes 5 or 10 min before I can take-off
    then it takes about 15-20 min. to run any better once it gets thru this "2nd warm up"
    it runs pretty good and strong,
    pops in the pipe tho'
    I did check, not adjust, the timing last weekend, it was @ 10 btdc
    the tach is way off too, gonna follw the post on that I saw here
    Any ideas,
    thanks John
    My Photo Bucket
  • Ken Talbot
    • 4251
    • Revelstoke, BC
    Carbs need to be cleaned and sync'd. Pay particular attention to the tiny orifice in the bottom of the float bowl that supplies fuel to the enrichener circuit.
    Ken Talbot
    • prometheus578
      XS-XJ Super Guru (RESIGNED)
      • Aug 2004
      • 4012
      • Olympia , Wa.
      I agree with Ken. (But find his new "Self Portrait" most disagreeable)
      Really, Ken. What's the deal with that?
      I'm sorry, but I find it a little... frightening?
      • Ken Talbot
        • 4251
        • Revelstoke, BC
        Not to worry, Prom, it won't be around long. Was playing around yesterday with an add-on from Photobocket called "Meez".
        Ken Talbot
        • underdog57
          • Jul 2006
          • 321
          • Alburgh , Vermont,054
          The moustache is disturbing , LOL
          1979 XS1100 SPECIAL (under 18,000 miles Sold 5/12/2016
          1982 XJ1100 MAXIM(PARTS BIKE??)shows 14,000 miles ??? Up for sale whole or parts
          • renegade_xs11g
            • 462
            • Mid-Michigan
            New Carb kits, had a few questions.....
            First Question has been answered:
            mains on a spec #1 & #4 get the 110's and #2 & #4 get the 120's
            Thanks for clearing that up gentlemen
            Now the bike: Stock 1980 XS1100 G (spec. not Mid-Nite)
            I've made a couple of minor mods...
            #1 removal of air box, I've opted for pods
            #2 I've replaced non-salvagable mufflers w/straight pipe
            1-7/8" ID 33" long from the end of the factory collector,
            no cross between the two sides.
            Really SOUNDS GREAT!!!
            Now the Question:
            Are the above described Mains gonna be correct,
            or should I do all 110's or something else????
            THANKS, John
            My Photo Bucket
            • renegade_xs11g
              • 462
              • Mid-Michigan
              OOPS
              I meant #2 & #3 get the 120's
              My Photo Bucket
                Hey Renegade,
                You didn't mention, or I don't remember what sizes of mains you found to begin with, but I would suspect 110's across all 4.
                The jetting guide in the tech tips....you have read it haven't you
                recommends about 3 sizes up on mains with both pods and aftermarket pipes. Since you already have a couple of 120's, you would only really need to get a couple more, and you would actually be 4 sizes up from the 110 stock.
                Not too many of us bother with the staggered mains that I know of? I've got Indy pods, and 4-1 and run 117.5's, but after my Dyno run a few years ago, was told I could have probably gone up another size which would be the 120's! YMMV!
