Thanks for the advice on the slipping clutch, it was just an adjustment
I had to take an air filter off and hold my hade over the mouth of the carb to get it to start.
I know, I know.
That's not the answer.
Still no time to rebuild those carbs.
In process of replacing a wheel bearing on the car,
I had to chase after a bearing puller, for the car
plus it was a very nice day. & I didn't want to drive the FREIGHTLINER
any way, I can't tell if it's an intermittant miss, or intermittant fire.
seems to be around 3000 rpm
motor is very cold blooded, it takes 5 or 10 min before I can take-off
then it takes about 15-20 min. to run any better once it gets thru this "2nd warm up"
it runs pretty good and strong,
pops in the pipe tho'
I did check, not adjust, the timing last weekend, it was @ 10 btdc
the tach is way off too, gonna follw the post on that I saw here
Any ideas,
thanks John
