Bad Coil
    Re: another problem
    TopCat as i previously mentioned i removed the battery from the bike because i went to hit the starter and the bike would not start.I push started it 2 times to get it going.I had the battery sitting on a charger for 3 1/2 hours and still the lights would not change.No bubbles or anything in the cells.I suspect one cell is dead as it did look pretty low. Battery is no good even though i tested it with a voltmeter and it read 12.26 volts.New battery is $45.00 at wal- mart.Took old battery off of charger and volts started to drop.Could the battery have an effect on spark?
    I'm running the same battery. I hope you read the instructions and put it on the charger FIRST! It needs a good DEEP charge to bring it up to capacity. If you start using it right out of the box, then it will not be able to reach it's full potential later!
    Yes, a low battery can affect the coils and spark. If it gets too low, the TCI will not work. Also, folks have reported some strange findings of weak spark on 1-3 or 2-4 combos, which are not shared by the same coil. The way the spark travels is out one plug, thru the engine and them back up thru the other plug back into the coil. When the voltage gets weak to the coil, it makes a weaker spark, but is sometimes enough to fire the 1st plug, but not the second on that same coil!
      • 2117
      Hobby Man,Went to a Sears hardware store( friend works there)and they had a load tester.Put the old battery on load tester and battery is - Dead -in the red after charging.Brand spanking new battery is on charge and will see what happens next!
      • datter
        • Feb 2007
        • 78
        • Nova Scotia, Canada
        Originally posted by randy
        TCI solder fix may be in order. Take a look at my profile and go to my www. for instructions
        Someone referred me to this fix, but your www link just goes to a pic of a very nice looking XS at the moment.
        Is the original fix page still up someplace?
        Rebuilt 1981 XS1100 H
        My story
        • randy
          • Dec 2003
          • 4521
          Oh, that was a VERY old post, I had to take my website down, sorry, but the process is described in words in some of the posts, no?
          Basically, remove the six cover screws and re-solder the row of pins that connect to the harness sockets. Use 60/40 rosin core solder and a small 15-30 watt soldering iron.
