I took the center stand off of my 1982 xj1100 and re-painted it with POR15 rust preventitive paint. everything worked out out fine but now i am trying to put it back on and i cant stretch the spring out enough to hook it to the teo hook up points. anyone know a trick that works for getting this to work? i can really get a screw driver or anything in the area....let me know if you can think of anything. thanks. -Joe
Center Stand Spring
Hook the spring first then install the bolts. Better leverage that wayPat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
"No one is totally useless. They can always be used as a bad example" -
Insert lots of washers in the spring coils...making it longer and longer until it is the length you need to install.
Easy, no fuss.Comment
I think I used a pair of channel locks and just pulled it. or maybe it was vice grips?"Beware of any man that owns a pig farm"
79 XS1100 modified standard
straight pipe 4-2 exhaust
Owned 83 Honda V65 Magna
Owned 02 Vstar 650 classic
owned 85 Honda Shadow VT 700CComment
Last time I did it I used a brake tool to pull the spring over the stud on the frame. You know, the old kind of tool that was used with drum brakes.Mike Giroir
79 XS-1100 Special
Once you un-can a can of worms, the only way to re-can them is with a bigger can.Comment
