Ignition module question.
  • Hired_Goon
    • 184
    • Perth WA Oz
    Ok, intrepid gurus, a quick question to try and work out which of the pictured modules may have been tinkered with.
    Presumably the cover would have been all set up the same from the factory so one of these has been opened and had the cover put on back to front. If I can work out which one then I know which unit not to put too much trust in.
    Any ideas?
    2
    Left one tampered with
    0.00%
    0
    Right one tampered with
    100.00%
    2
    1981 XJ550RH
    1978 XS1100E The Wildebeast
    1978 XS1100F X Streem
    1980 XS1100G (with an E motor)(parts bike)
    Jet/Mod Calculator
    Speed/Gearing Calculator
    • 5069
    Well...the one on the left looks pretty "hammered" with those broken pieces near the clips.
    • HobbyMan
      MeatHead Idiot "GURU"
      • 1801
      • Colleyville, TX
      The cover is on the wrong way on the right one
      Acta Non Verba
      • HobbyMan
        • 1801
        • Colleyville, TX
        I suggest you remove the cover and clean any corrosion that might be built up on the board.
        Acta Non Verba
        • Hired_Goon
          • 184
          • Perth WA Oz
          Cool, Looks like the right one has been opened. It is a good one though as it runs fine and I don't have any problems with it at all.
          The one on the left is my spare and was on an XS1100 that was used as a farm bike. Knobly tires and all. I ripped the cover off it after the photo and the inside is in mint condition. No corrosion or dirt at all. I have had an engine running with it so I know it works but I am trying to work out which unit to put on my third XS to see if it eliminates a stutter and ping winding open the throttle.
          Cheers
          HG
          1981 XJ550RH
          Jet/Mod Calculator
            • 5069
            Ah, OK, a trick question!
            • Hired_Goon
              • 184
              • Perth WA Oz
              Lol, No, not really. Just wanted to work out which one may have been tinkered with. Helps to know the background of swappable items.
              1981 XJ550RH
              Jet/Mod Calculator
