picked up my bike last night!
  • #16
    A quart of gear lube will be more than enough. The middle drive will take 10 oz, and the book says that the final drive takes 10 oz also, but I can never get that much in it. I just fill it to just below the bottom of the the filler hole threads.
    • #17
      yea, i did a little research and found thats what people have been saying
      i think im gonna make one of the dipsticks
      get a dollar store garbage can and cut my dipstick out of that
      im obsessed with changing all of my fluids now
      im scared to remove the allen head bolts, but im gonna go for it, should be alright, hopefully
      1980 XS1100SG - almost done
      • #18
        Let them soak in some PBlaster or other penetrating oil for a bit first.
        80 XS1100SG
        81 XS400SH
        Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
        A Few Animations I've Made
        • #19
          Make sure you can remove the filler plug BEFORE you remove the drain plug. It would suck to get it drained, and then discover that you can't fill it back up. At least his way you can still ride until you are able to remove the plug.
          • #20
            gettin ready for another season
            chicago winter finally seems to be coming to an end
            its been an interesting one thats for sure
            just picked up some harley fatboy pipes off ebay, im pretty excited about that
            i drilled some holes in my stock pipes and im ready for a different sound this season
            ill update pics when i throw those 'new' pipes on
            • #21
              Black plug in front
              is the chain tensioner. Most people new to these machines don't immediately identify that thing right away because these things run backwards compared to all the others. Be sure to check the manual before attempting to adjust.
              Drilled airbox
              Tkat fork brace
              Hardly mufflers
              late model carbs
              Newer style fuses
              Oil pressure guage
              Custom security system
              Stainless braid brake lines
