Well, up here in the great white north the days are getting shorter and colder
as much as it hurts to put the XS into hibernation for the winter, it will give me a chance to catch up on things with her (always find the silver lining, right?)
the list includes, but is not limited to:
-fork rebuild with new oil and seals
-inspect and adjust head bearings
-grease driveshaft splines
-dissassemble, inspect, and bleed rear brake system
-swap right front rotor for rear rotor (front one has a slight warp which i hope will be less noticable when its on the rear)
-work on some kind of removable hard luggage system
So, whats on everyone else's lists?
btw, I dont want to hear about any of you that live somwhere that stays warm year round- too dang depressing
-- but if you must, I suppose I'd rub it in too
as much as it hurts to put the XS into hibernation for the winter, it will give me a chance to catch up on things with her (always find the silver lining, right?)the list includes, but is not limited to:
- could be me!) didn't put the tab washer back properly on the primary gear that drives the clutch – Doh – rebuild engine to clear out aluminium swarf.
