Exhaust doesn't fit
  • SiP
    • 438
    • Medicine Hat, Canada
    Exhaust doesn't fit
    Got my new 4-1 mac yesterday and thought I'd throw it on tonight. However it doesn't make it tight up to the head 'cos the oil cooler pipes are in the way.
    Can I:
    1. Use a flexi steel pipe instead of the solid metal ones that I can then route to my fancy? If so do I need a special mating connection or can I just hacksaw of the metal pipe by the filter and secure the flexi to the stub? (This I think is my favorite option so far)
    2. Bend the pipe and hence reposition them so that the exhaust clears them? - not sure this will work as I think that even if I move them to the side of the frame, there still won't be enough room and they will also rest against the exhaust.
    3. Is there a kit designed for this and if so how much roughly?
    As ever thanks in advance.
    Si
    Si Parker
    '81 XS1100H
    Tkat brace, new coils/wires/plugs, refurbed carbs (thanks 81 xsproject), recon'd top end, windshield (thanks dpotter58), resprayed tank and panels, 4-1 exhaust, sweet xs pod filters, in line fuel filters, progressive springs, thick hand grips, jumped headlight relay.
    I had installed a OEM cooler from an 850 triple on my bike, and I had to cut the steel lines, and use cloth braided hose in it's place. I cut the metal pipes about 1 inch from from the adapter plate, AND I had to braze some raised ridges around the ends of the pipe, sort of like a flare, to keep the hose from blowing off. You'll need to do that where you cut the upper end of the steel line also. DAMHIK.
    • SiP
      • 438
      Nice looker John - I checked out your web album. I see what you mean, isn't that cooler a bit smaller than the original? Why did you have to change it? Can't I just put a different type of pipe on it and keep the original?
      As a side note, what is the reasoning behind the 1 & 4 cyls and 2 & 3 being together. My old stock exhaust is 1&2, 3&4.
      Sorry for more questions.
      Si Parker
      '81 XS1100H
      • SiP
        • 438
        The advantage of all this is - I was impatient to get my new pipes on but now I have to wait I'll get some of that ceramic spray for the insides.
        Si Parker
        '81 XS1100H
          Sip
          Those pics don't have the OEM 850 cooler...that is a Lockhart brand cooler. The 850 cooler wouldn't bolt up to the frame, so I had to secure it with tie wraps. I replaced the 850 cooler a few years ago when I found the Lockhart on a 78E that I bought for parts. The 78 also had the Spaghetti Pipes on it. I thought they looked pretty cool, so I pulled the MNS pipes off of my bike and installed the Jardines, and sold the MNS pipes. The pics of the engine disassembled is when I did the bigbore a few years ago.
