oil change - torque specs
  • bryzx2
    • Jun 2004
    • 28
    • Wisconsin
    I changed the oil on my MS and started her up to watch it all pour out from the filter assembly. I bought a new o-ring and would like to know the proper torque spec for the oil filter bolt.
  • Snow
    • Oct 2002
    • 1041
    • Tallahassee, FL
    It was most likely due to the o-ring getting pinched when installed...they are a bugger to get in right. Try replacing the o-ring, but this time put some grease on the oil filter cover before inserting the o-ring. Torque shouldn't be very high, but I don't have my manual in front of me.
    • bryzx2
      • Jun 2004
      • 28
      • Wisconsin
      I got it
      My Clymer's manual finally came today and the oil filter bolt gets torqued to 23 ft lbs.
        Hey Bryzx2,
        Like Snow said, it wasn't that you had the mounting bolt too loose, but that you didn't have the O-ring positioned properly. That chamber is under a lot of pressure since the oil pump is sending the oil directly to that chamber first before going throughout the rest of the engine!
        Along with the large O-ring, there's also a smaller one around the filter bolt. Hopefully you got one of those with your filter as well.
        There's also a couple of notches/protrusions on one end of the chamber cover which align with the engine case as the bolt is being tightened up keep the chamber from spinning.
        • bryzx2
          • Jun 2004
          • 28
          • Wisconsin
          Thanks TopCat. I will try that and hopefully get her out this week since the snow from last week is gone and it is finally warming up a bit.
