windshield cleaning
  • eroellig
    • Oct 2005
    • 229
    • Arkansas
    windshield cleaning
    Well, I'm starting to thing about the faring a little. I shouldn't have TOO much more to go before I can remount it.
    The PO had taped his For Sale sign onto the windshield with duct tape. Now, I have a glob of DT glop to deal with. What would be the best thing to clean it with? Petrolium based solvants are out due to crazing the material, right?
    Eric
    Eric Roellig
    1980 SG w Windjammer V & KG hard bags
    **Very first bike**
    Current condition: Running!!! Lead, follow or get the #^%# out of my way!!!!!!
    You'll be fine...................give a shot of Brake-Kleen on a lean rag and wipe away. After which you can polish it up some and look real clear using Meguiar's No. 17 Clear Plastic Cleaner. You get a bottle of this at your local automotive paint supplier............hope that answers your question.
    • BLUEJEEPLAB
      • Sep 2005
      • 703
      • Miami Valley, Ohio
      Goo Be Gone, a citris based cleaner works pretty well. I used it to clean up double sided tape the PO had used to mount the GPS.
      I use Meguiars Plastix polish on my windshield and the visors of the Helmets. It also works really good on Jeep soft top windows.
      Papa Gino
      79 and something XS 1100 Special "Battle Cruiser"
      78 XT 500 "Old Shaky"
      02 Kawasaki Concours "Connie"
      • Jerry
        XS & TRUE XJ GURU
        • 3023
        • Elma, IA.
        Well, I have always used with Novus plastic polish #2, medium, or Honda's aresol windshield cleaner. Either one is about $10 - $12 but lasts a long time. Most bike shops will have one or both of these items.
        Have not tried them, but would not put solvents on my windshield, ever. I don't even use gas station windshield washer bucket 'wash' on my Vetter windshield.
        Have found that those blue paper shop towls sold at most auto parts places and wallyworld work very well to clean windshields and visors.
        Jerry Fields
        '82 XJ 'Sojourn'
        '06 Concours
        My Galleries Page.
        My Blog Page.
        • 0011mixam
          • Jan 2006
          • 42
          • Winnipeg, Manitoba, Canada
          Baby oil will take the sticky stuff off. Then just use some mild soap and water to take the oil off. Works every time.
          Perry
          '82 XJ1100 (Second Childhood)
          Frame-up Restoration
          As Original as I Could Keep It
          • eroellig
            • Oct 2005
            • 229
            • Arkansas
            Thanks for the suggestions, guys.
            Eric
            Eric Roellig
            **Very first bike**
              Another EXCELLENT product is called Plexus. It comes in a spray can and is made specifically for the plexiglass and lexan bike windshields. If you follow the directions, it will actually fill fine scratches and scuffs. My old windshield is pretty rough, but with this stuff, it helps tremendously and makes a huge difference at night with other headlights hitting it. Without it, all you see is the scratches instead of the road.
              Just another option.
              • ricks1100
                • Nov 2006
                • 14
                • Campbell, CA
                bieng an aircraft mechanic we use alot of different cleaners for plastic and acrylic windshields. I have used the plexus product repeatedly and have found it quite effective. Just remember that it is a polish so use two soft terry cloth towels one to apply the polish after spraying the windshield and the other to "buff" out the polish.
                Do NOT use lemon pledge this does make the glass look shiny and does fill in a lot of scratches but will contaminate the plastic as will any other oil based product, which will cause the plastic to cloud and craze. If you have extensive scratches there is a plastic rubbing compound availible that when used with a power buffer can completely remove most noticable scratches. Tap Plastics sells it but use caution optical quality will be a factor.
                hope this helps
                keep em running!
                • red bandit
                  • 955
                  • central michigan
                  Peanut butter....That's right, peanut butter takes sticky stuff off.
                  79 SF parts bike.
                  • eroellig
                    • Oct 2005
                    • 229
                    • Arkansas
                    That's interesting. I used to read some of the pilot & aircraft owners news groups years ago (the hardware is facinating). They all seemed to use Lemon Pledge exclusively.
                    Eric
                    Originally posted by ricks1100
                    bieng an aircraft mechanic we use alot of different cleaners for plastic and acrylic windshields. [...]
                    Do NOT use lemon pledge this does make the glass look shiny and does fill in a lot of scratches but will contaminate the plastic as will any other oil based product, which will cause the plastic to cloud and craze. [...]
                    Eric Roellig
                    **Very first bike**
