VAC INLETS ON CARBS go to?????
  • XSRIK
    • Jun 2006
    • 45
    • meeker colorado
    Greetings people of higher XS intelligence or is that excess intelligence? I humbly seek guidance to my quandry. It is thus:
    I'm wondering where to hook these vacuum inlets on the carbs to? There is no octopus octopi or any other tentacled type critter on this bike. I am using the "Prime" setting for fuel and it seems to work well after the bike is warmed up. cold starting is a beeeyawwtchhh! I currently have the vac lines running from the carbs to the inlets atop the of the air box as I "Think" thats where they were hooked up when the illustrious "shaft" came to live here. comments? suggestions? verbal snares? wot to do's???
    ahhh....springtime in the Rockies brrrrr............
    XSRIK
    "I once saw a man with wooden legs and real feet I said to him "Hey buddy do you know what time it is?" and he replied "Yeah, but not right now".............
    79 XS1100F "Talkin' 'bout shaft"
    77 CB750 A "Dumpster classic" aka "Rattus Ottomaticus"
    You have an early model standard, so assuming nothing has been changed, here's your line-up:
    - the vacuum nipples on the #1 and #4 intake manifolds can be capped off
    - the vacuum nipple on the #2 intake manifold goes to the small, forward-facing nipple on the left petcock
    - the vacuum nipple on the #3 intake manifold goes to the small, forward-facing nipple on the right petcock
    - the upper "T" nipple between carb #1 and #2 is connected to the nipple on the left side of the upper half of the airbox. This is an atmospheric vent for the float bowls on #1 and #2
    - the upper "T" nipple between carb #3 and #4 is connected to the nipple on the right side of the upper half of the airbox. This is an atmospheric vent for the float bowls on #3 and #4
    - the vacuum nipple on the engine side of the body of carb #2 connects to the line that goes into the vacuum advance mechanism behind the left side engine cover
    - the lower "T" nipples between carb #1 and #2, and between #3 and #4, each connect to a fuel supply nipple on one of the petcocks. I like to cross these over with a slightly longer hose so the right side petcock supplies the left side carbs and vice-versa.
    • XSRIK
      • Jun 2006
      • 45
      • meeker colorado
      thanks for the info! This completes my carb set up!
      XSRIK
