Front master cylinder
  • Filter
  • Front master cylinder
    How do you get the snap ring out of the front master cylinder on a 1980 xs1100g.None of my snap ring pliers are long enough.Is there a pair from craftsman or Matco that will work?Or is there something special i need to get?
    1980 XS1100g
  • #2
    Hey Nate,
    A search for "long snap ring plier" revealed several threads, this one also has link to MikesXS that sells special ones. But you can find them at Sears as well.
    • #3
      I believe at least one of the links you will find with the search engine talks about grinding down the ends of a cheap pair of needlenose pliers.
      • #4
        Yes just got done reading those 2 threads.Ended up getting it out with a straight pick earlier.Thank you for the help.
        1980 XS1100g
        • #5
          My craftsman pliers work well enough. Although, you kinda have to be a craftsman to use them. I hold the plunger down with a flat screw driver. I slide it across horozontally where the handle goes. You must have the MC held on the ground with your left hand, then the small craftsman pliers work fine.
          Acta Non Verba
