Hey Dan,
Thanks for the info, however I've alread ordered the tapered NPT taps, even though I am using the tapered fittings!
I do use a dead center on my lathe when I'm tapping the mounting threads into my standard SOFA plates, cause I already have them centered in the lathe chuck, and the dead center fits nicely in the tailstock to help ensure a straight line! And yes, I've learned the benefit of LUBE during my machining adventures!
But these Oil plates are being tapped on their ends, so I just have them held in a bench vice, have a nice large handle from Sears for the tap.
Perhaps you can answer this? I was using a 27/64" drill bit which is what I had found and was told to use for the 1/4" NPT fittings! But I found that it was barely big enough to get the tip end of the tap into the hole. I recently used a 7/16"=28/64" size, the tap fitted a bit farther into it, but was wondering if a 15/32"=30/64" would be a better size, and easier to get aligned and allow me to cut the threads a bit deeper so that the fitting would screw in deeper into the piece??
Thanks in advance for helping a novice/apprentice machinist/hobbyist!
And you'll need to be sure that you have an additional ~.75" of clearance between your existing cooler/filter chamber and the pipes.
