XJ Reserve Lighting Unit bypass?
  • Fredjohny
    • 74
    • Gibsons, BC Canada
    the color codes are different on my XJ1100, its a 82.
    I just want it out of the way, does anyone know the
    wire colors for a XJ?
    thanks
    82 XJ1100 Maxim
    80 XS1100 engine and parts doner
    Awsome machine.....love going on rides.....
    black on black
    Wiring Diagram!
    Hey FredJohny,
    Go or right click on this link and SAVE AS, it's a zipped PDF file of the XJ wiring diagram, should have the color codes on it as well. I think it's a B-W version but has the Yamaha wire color code letters next to the wires. Did you see the tech tip about how to bypass/remove your RLU?
    • Fredjohny
      • 74
      I read the one on a xs... the wire colors are not there?
      82 XJ1100 Maxim
      black on black
      • Fredjohny
        • 74
        sorry...the wire colors on my bike are not the same...the only color is the first one...the rest are different color wires ....
        82 XJ1100 Maxim
        black on black
          Hey Fred,
          Yeah, that's true, but you can also D/L the wiring diagrams for one of the XS's, and review the wires involved in the tech tip to determine what each wire is...like power from the fuse box, etc., and apply that to the XJ wiring diagram you have so that you could figure out which wires to cut, which ones to join together, etc.! I know, a lot more work, but UNLESS Jerry=XJ guru has done it, then "WE" just don't have the info about it?
          HOWEVER, IF you do figure it out, would be nice of you for the betterment of the XS-XJ community to post your results so that it could be added to that tech tip for other unfortunate XJ owners that suffer the RLU failure!
          • Fredjohny
            • 74
            thanks TC...I am going to figure it out....was hoping for a faster way......
            I will post the XJ way ....... soon
            82 XJ1100 Maxim
            black on black
              Hey Fred,
              I just editted this thread adding the XJ part. I just saw that JERRY, our XJ guru was one, but this thread must not have caught his eye, cause he didn't reply? That, or he may not know how to bypass the RLU on the XJ? I'll drop him a PM!
                Hey Fred,
                • Fredjohny
                  • 74
                  Thanks for your help, T.C.
                  82 XJ1100 Maxim
                  black on black
