short version
OK, here's some answeres to your questions. Hobby, it runs fine at any speed, but after cruising for a while acts like it's starving for fuel. The PO removed the petcock towers so It's basically on prime all the time, but no fuel leaks. The engine will die if run long enough under a heavy load, i.e. mid revs, uphill with me and backpack as cargo. The fuel lines looked a little long to me when I took the carbs off, will try that fix first. Also a HD mechanic I know said the vacuum boots in the carbs can pinhole and cause a similar problem. Thought I'd check that too. Will give you an update after I finish these. Thanks again!
