Another Homemade Vacuum Sync'er
  • 81xsproject
    • 3185
    • Fortuna, CA
    I found this on another site and thought I'd post it here.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    nice, mercury?
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
    • 81xsproject
      • 3185
      • Fortuna, CA
      no, it is oil. You can mix with kerosene for better visibility.
      '81 XS1100 SH
      Sep. 12th 2015
      RIP
      • mason79
        • Mar 2006
        • 1359
        • los angeles, ca
        then why can't they use oil instead of the hard to get mercury? on the mercury stix
        History
        85 Yamaha FJ 1100
        79 yamaha xs1100f
        03 honda cbr 600 f4
        91 yamaha fzr 600
        84 yamaha fj 1100
        82 yamaha seca 750
        87 yamaha fazer
        86 yamaha maxim x
        82 yamaha vision
        78 yamaha rd 400
          On this version, all four channels are connected to a common manifold, and the system is sealed. As one carb pulls a bit more vacuum, it draws one channel up, but the others in effect pull it back down.
          On a mercury unit each channel is sitting in an open reservoir, so the vacuum is pulling the weight of a column of mercury. It is only the weight of the mercury column that prevents it getting sucked into the carb (unless you are running without a restrictor, and if you suddenly chop the throttle at high speed.
          If you happened to try this unit with one channel unplugged, it would suck the oil into a carb in an instant.
          This is a very interesting unit, and it could no doubt be built with the channels much closer and with a more sophisticated manifold across the bottom. That would make it more compact, like the mercury units.
          • BLUEJEEPLAB
            • Sep 2005
            • 703
            • Miami Valley, Ohio
            Always wondered how the Synchonizers worked, now I know. Old Dogs can learn new tricks.
            I happened on an aid for synching the carbs this winter, quite by very unfortunate accident. I grabbed the wrong gas can for my new 2 stroke snowblower and got exactly two blowings out of it before I siezed it (The Chainsaw Can is now sporting a very large "PM" in its side). Anyhow, after I sadly decided that it was beyond economic repair, I looked at the little plastic tank that held the offending gas and realized that it was perfect as a gravity tank for tank off carb tuning, it even has a little strap for hanging and holds about a quart of gas. It is the only remaining reminder of my stupidity.
            Papa Gino
            79 and something XS 1100 Special "Battle Cruiser"
            78 XT 500 "Old Shaky"
            02 Kawasaki Concours "Connie"
              Because it works by difference AND it needs the weight of the column to work, you can imagine that if you have a 2 inch difference showing a regular mercury stick unit (one cylinder to the next), you will show about 2 feet of difference of oil. (that is if mercury has an s.g. of 10 and oil has an s.g. of 0.85). The good part is that if the engine sucks it in, you don't create an extreamly hazardous atmosphere!
              Originally posted by Ken Talbot
              SOME SNIPPAGE
              • randy
                • Dec 2003
                • 4521
                Yeah, but the bad part is if the engine sucks it in, you could have hydrostatic lock and wind up with a bent connecting rod!
                • prometheus578
                  XS-XJ Super Guru (RESIGNED)
                  • Aug 2004
                  • 4012
                  • Olympia , Wa.
                  "Not for me, Papa!"
                  I've written this little episode down in the file I keep on everybody.
                  I'll help you remember it from time to time...
                  • 81xsproject
                    • 3185
                    • Fortuna, CA
                    as was briefly mentioned, another advantage is accuracy. Because of the large difference in weight between oil and mercury, very small height differences in the mercury would show as drastic height differences in the oil.
                    '81 XS1100 SH
                    Sep. 12th 2015
                    RIP
                      But, with this homemade unit, you're not really dealing with the weight of the column of oil because of the 'closed loop' configuration. I have never built one to try, but I don't think the variations would necessarily be that much more than in a set of open reservoir mercury sticks.
                      • 81xsproject
                        • 3185
                        • Fortuna, CA
                        touche!!
                        '81 XS1100 SH
                        Sep. 12th 2015
                        RIP
                        • BLUEJEEPLAB
                          • Sep 2005
                          • 703
                          Prom,
                          Great, now maybe SWMBO will quit doing it...
                          Papa Gino
                          • mason79
                            • Mar 2006
                            • 1359
                            • los angeles, ca
                            then vacuum gauges would be the most accurate right?
                            History
                            85 Yamaha FJ 1100
                            79 yamaha xs1100f
                            03 honda cbr 600 f4
                            91 yamaha fzr 600
                            84 yamaha fj 1100
                            82 yamaha seca 750
                            87 yamaha fazer
                            86 yamaha maxim x
                            82 yamaha vision
                            78 yamaha rd 400
                              The mercury stix are the easiest to use, IMHO. I use mine about 3 or 4 times a year, and it's just set all the lines. Vacume gauges, you have to try and set all the needles the same, as they are bouncing.
