Before I rebuild/replace the fuel petcocks
  • mason79
    • Mar 2006
    • 1351
    • los angeles, ca
    the reason you only dribble on reserve is the fuel level is low and the upper feed is not exposed to gas, you have 2 petcocks is only one leaking? i'm assuming that is the case, yes an inlineshut off will work, or just cap of the offending unit and splice the single petcock to feed both banks of carb, with a y or t fitting.
    you can take it apart and clean it up abit that may do the trick, would not hurt to take the carbs out and inspect the tiny parts and clean
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
    • nate
      • Sep 2006
      • 116
      • PA
      I have the carb bank out waiting to get intakes.Just not sure if i want to mess with the carbs or take them some where.I only put a gallon and half of gas in the tank i moved it around on the reserve and on position.Yes only the right side leaked.
      1980 XS1100g
      • nate
        • Sep 2006
        • 116
        • PA
        Any tips on cleaning the carbs?
        1980 XS1100g
        • mason79
          • Mar 2006
          • 1351
          • los angeles, ca
          since you have it apart and awaiting parts, i'd say look at the right side and under forum scroll down to carburaters, under maintenance, repair and mods and read read read, you will find all you need to cleanem up
          History
          85 Yamaha FJ 1100
          79 yamaha xs1100f
          03 honda cbr 600 f4
          91 yamaha fzr 600
          84 yamaha fj 1100
          82 yamaha seca 750
          87 yamaha fazer
          86 yamaha maxim x
          82 yamaha vision
          78 yamaha rd 400
          • nate
            • Sep 2006
            • 116
            • PA
            Will do i browsed threw the repair section.Have not had time to sit down and read everything yet.But im getting there.lol
            1980 XS1100g
