Before I rebuild/replace the fuel petcocks
  • nate
    • Sep 2006
    • 116
    • PA
    Before i replace or rebuild the fuel petcocks on my 1980 xs11.Is there a way to leak test them while i have the tank off?
    When the bike sits more then 1 day i have fuel in the oil.Or at least the oil smells like fuel.Or is this a symptom of something else?
    Thanks Nate.
    1980 XS1100g
  • randy
    • Dec 2003
    • 4521
    Nate,
    With the tank off, do the petcocks dribble fuel? If so, I'd say they need rebuilding. Also float valves in the carbs are probably leaking, allowing fuel to overflow into the intake tract, down the cylinders and past the rings.
    • mason79
      • Mar 2006
      • 1359
      • los angeles, ca
      change your oil,
      pull the tank,
      flip it to prime, if it flows good,
      flip it to run, if it flows no good
      flip it to reserve if it flowsno good,
      rebuild time, or at least take it apart and see and clean bend springs etc. and hope...
      if you want to go manual, mikes xs manual replacement for the 78-84 might fit, i have one ordered and will let yawl know...
      or i have a parts n more getup for sale.
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
      • 81xsproject
        • 3185
        • Fortuna, CA
        The petcocks are very simple inside and can be rebuilt cheaply. Bikebandit has the rubber valve seal for 8.75 ea. This and an o-ring you could get at the hardware store are all you need, unless you have the vacuum petcocks (which I know nothing about). If you don't want to do the leg work, Cycle Re-cycle has a kit for both at around $30. The other thing to be sure of is that your floats aren't set too high.
        All this brings up another point. If you put your year and make in you signature line, it makes it easier for the rest of us to help you faster.
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
        • nate
          • Sep 2006
          • 116
          • PA
          I drained the tank so theres no fuel in it at current,and its off the bike.But know that you told me how to check I'll put some in it and see what happens.Yes they are vacuum petcocks.Figured id ask now instead of putting it back together and having to tear it back apart.So check the petcocks?If that isn't the problem tear the carb apart?
          Thank You
          Nate
          1980 XS1100g
          • mason79
            • Mar 2006
            • 1359
            • los angeles, ca
            if you have gas in the oil, there is a chance you will have gas in the air box, gas when it overcomes a float valve can and do go everywere,
            float valves leaking
            float has holes and sinking leaving valves open
            float rubbing against the bowl jamming it open, all the same leak
            if it stops on the center stand, it maybe the rubbing culprit,
            are you sure there is gas in the oil?
            History
            85 Yamaha FJ 1100
            79 yamaha xs1100f
            03 honda cbr 600 f4
            91 yamaha fzr 600
            84 yamaha fj 1100
            82 yamaha seca 750
            87 yamaha fazer
            86 yamaha maxim x
            82 yamaha vision
            78 yamaha rd 400
            • nate
              • Sep 2006
              • 116
              • PA
              The oil sure smelt like gas.And when i pulled the bottom half of the air cleaner off i got hit with a strong smell of gas.So were thinking float valves?How much work are they to check out/replace/repair?
              1980 XS1100g
                It is easy if you have a Ken Talbot float-pin-pusher tool. If you have to tap them out, it can be like diffusing an atomic bomb.
                • mason79
                  • Mar 2006
                  • 1359
                  • los angeles, ca
                  it could smell like gas because it is the carbs but may not be leaking and you are over sensitive to the odor,
                  fill the tank and check the petcocks first, if they leak fix those first.
                  and write up a history of you ownership and about the bike, this could avoid a carb removal.
                  History
                  85 Yamaha FJ 1100
                  79 yamaha xs1100f
                  03 honda cbr 600 f4
                  91 yamaha fzr 600
                  84 yamaha fj 1100
                  82 yamaha seca 750
                  87 yamaha fazer
                  86 yamaha maxim x
                  82 yamaha vision
                  78 yamaha rd 400
                  • midnight1980
                    • Mar 2007
                    • 312
                    • cedar city, utah
                    humm what one here?
                    Description BikeBandit.com Part Number
                    Qty.
                    Unit Price
                    1: PIPE,JOINT 1
                    ,(5MT6)
                    34272-001
                    $4.10
                    2: HOSE
                    (L130)
                    351521-001
                    $3.57
                    3: HOSE
                    ,KC
                    351848-001
                    $4.11
                    6: HOSE
                    351861-001
                    $2.59
                    9: CLIP,SCISSOR
                    ,U49 (2C05)
                    864-001
                    $1.56
                    10: CLIP,SCISSOR
                    (#1,3,4)
                    353460-001
                    $0.86
                    11: CLIP,SCISSOR
                    (YMUS)
                    353429-001
                    $1.82
                    13: DISCONTINUED
                    34273-001
                    $45.40
                    14: NET,FILTER 1
                    40994-001
                    $11.14
                    15: GASKET
                    26142-001
                    $2.94
                    16: SCREW, PAN HEAD
                    CARBURETOR 2
                    366184-001
                    $0.82
                    17: GASKET
                    34276-001
                    $1.47
                    20: WASHER,WAVE
                    357-001
                    $1.36
                    21: SEAL,COCK
                    34280-001
                    $4.33
                    22: VALVE
                    34277-001
                    $8.75
                    23: SCREW, PAN
                    (U49)
                    366640-001
                    $0.67
                    25: WASHER,PLATE
                    (5HN8)
                    4832-001
                    $0.45
                    26: DISCONTINUED
                    34274-001
                    $42.84
                    39: DIAPHRAGM ASY
                    34275-001
                    $57.52
                    40: SCREW, PAN HEAD
                    366709-001
                    $2.92
                    41: WASHER,SPRING
                    ((M/T)) [WASHER,SPRING]
                    358142-001
                    $0.45
                      He has vacuum actuated petcocks, and that diagram is for a Special. Let's not confuse him with an octopus' plumbing, when he has a Standard.
                      • 81xsproject
                        • 3185
                        • Fortuna, CA
                        Where's TC when you need a good summary? So, to sum up,
                        [list=1][*]If you have gas in oil, you definately have a float valve issue[*]If gas drips from fuel lines while petcocks are OFF, petcocks need restoring[/list=1]
                        It is worth tearing the petcocks apart before deciding on rebuilding them. If the rubber valve is good, sometimes a good cleaning, a little lube, and stiffening of the spring washer will do it. I imagine crap from the tank could get in there and block the diaphragm from sealing properly (again, I know squat about the standard petcocks ) Sorry to repeat everything every one said, but it was getting a little scattered.
                        '81 XS1100 SH
                        Sep. 12th 2015
                        RIP
                        • 81xsproject
                          • 3185
                          • Fortuna, CA
                          standard?
                          '81 XS1100 SH
                          Sep. 12th 2015
                          RIP
                          • randy
                            • Dec 2003
                            • 4521
                            IMHO;
                            If you have gas in oil, you definately have a float valve (or float)issue AND a petcock issue.
                            Both of them have to be leaking to get a significant amount of fuel in the oil.
                            And, BTW, the first thing to 'go' in the petcock is the o-ring on the tip of the diaphram, not shown in any of those diagrams!
                            • nate
                              • Sep 2006
                              • 116
                              • PA
                              Hi guys thank you for being patience with me,and Thank you for being so helpful.
                              Ok so i put some gas in the tank tonight.The right side petcock dribbles gas when on reserve but not on run,and flows on prime.81xsproject there is no off.So time to rebuild that petcock?And a def float problem?Can i splice the gas line and put a small petcock with on/off inline as a temp fix?
                              1980 XS1100g
