Hose help with pics
  • nate
    • Sep 2006
    • 116
    • PA
    Hose help with pics
    Hello.
    I took my 1980 xs1100 apart to replace the carb holders/joints.I don't remember taking this hose off.Could someone be kinda enough to tell me where it is supposed to go?
    Thanks nate
    1980 XS1100g
  • 79XS11F
    • Jul 2006
    • 3563
    • Ottawa, Ont. Canada
    That little middle gear vent hose goes right over the back of the engine and through the hose keeper where your battery hose is also routed.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • John
      • 5117
      Actually
      The mid drive hose (the small one in the pic) is routed up under the seat, behind the airbox, and attaches to a bracket that bolts to the frame where the upper air box bolt bolts to the frame. That is the corect location for that hose. Your hose bracket may have been removed by the PO, but this is the proper location for it.
      • nate
        • Sep 2006
        • 116
        • PA
        So it does not get hooked to anything.That end stay opened?
        Thanks nate
        1980 XS1100g
        • mason79
          • Mar 2006
          • 1355
          • los angeles, ca
          yes it stays open, and should be vented high, the bracket that holds it is attached to the top bolt that holds the airbox to the frame visable when the gastank is removed
          History
          85 Yamaha FJ 1100
          79 yamaha xs1100f
          03 honda cbr 600 f4
          91 yamaha fzr 600
          84 yamaha fj 1100
          82 yamaha seca 750
          87 yamaha fazer
          86 yamaha maxim x
          82 yamaha vision
          78 yamaha rd 400
          • John
            • 5117
            Yes it stays open. I didn't see the small flat bracket that the hose is secured to in the pic, but the bracket should be bolted to the same attaching point that the upper bolt for the airbox bolts to. In fact, the upper airbox bolt holds the vent hose bracket in place also.
            I have a pic of this bracket and it's location, but it is stored in my other 'puter, and that machine is down right now. I am using a borrowed computer at the present time.
            • nate
              • Sep 2006
              • 116
              • PA
              Kewl just wanted to make sure where it goes.Yes the brackets for the air box are off the bike currently.
              1980 XS1100g
              • John
                • 5117
                Do you have a flat one with a little hook shape at one end? The hose goes in that hook shape.
                • nate
                  • Sep 2006
                  • 116
                  • PA
                  Yeah theres that one and another one.
                  1980 XS1100g
                  • HobbyMan
                    MeatHead Idiot "GURU"
                    • Jul 2006
                    • 1801
                    • Colleyville, TX
                    There should be another clamp on the side of the airbox for the fuel tank drain hose. BTW: If anyone has theirs routed down to the ground, you might want to think about relocating it to the top. Or am I just paranoid?
                    Acta Non Verba
                    • audijunky
                      • Apr 2006
                      • 707
                      • VA
                      Hobbyman , are you talking about the fuel tank drain hose? If so I would suggest running it to the ground, that hose allows overfill or splashing gas that gets into the The "tray" around the gas fill hole to drain. If you route it higher the hose might just fill up with gas and just sit there, or it may leak onto something you dont want gas on.
                      79 XS1100 modified standard
                      straight pipe 4-2 exhaust
                      Owned 83 Honda V65 Magna
                      Owned 02 Vstar 650 classic
                      owned 85 Honda Shadow VT 700C
                      • HobbyMan
                        • Jul 2006
                        • 1801
                        • Colleyville, TX
                        I am sorry, The fuel tank vent goes down. Any other way would defeat the purpose of having the hose. I meant the middle drive gear vent. Wouldn't dust'n'stuff get inn to the MD if it was routed down?
                        Acta Non Verba
                        • audijunky
                          • Apr 2006
                          • 707
                          • VA
                          You should hook the middle gear vent hose to the airbox if you still have one. If not I think the consensus is to put a small filter on it and route it upward, (between pod filters). I just left mine in its preformed shape and had the end pointing toward the battery. I did notice while sitting at a light that it works, Had some oil residue(steam) I guess coming out of it when idling.
                          • nate
                            • Sep 2006
                            • 116
                            • PA
                            Yeah i still have a airbox the bike is apart right now wait on parts to get here.
                            1980 XS1100g
                            • John
                              • 5117
                              There is no place on the airbox for it. You would have to fabricate a nipple on the airbox to attach it there, and then you may put the drive in a slight vacuum. I don't know if that would hurt anything tho...
