Frankenstein and SWMBO's Rear end
  • mro
    • Oct 2005
    • 4276
    • Hayward, California
    Why not install the rear alum grab bar off of a special
    Don't think it will fit on a standard.
    mro
      • 8077
      That looks like a good place to mount a leather tool bag. I saw it done that way on a 650 Special.
      • cloerts
        • Mar 2007
        • 153
        • Tahlequah, OK
        LED and Baggin
        Ok, so far LED conversion and Leather tool bag are my favorites. I do need some sort of grab bar. Will a special bar work on my standard frame?
        Casey
        1980 xs1100g "Frankenstein" (Now with a mind of his own!)
        "What do you mean I can't park this thing here?"
        "Shiny side up? I don't have a shiny side."
          Hey Cloerts,
          I have an 81H frame, and the grab bar from a 80-81 MNS, and it fits the shock mounts up front. On the frame, there is a hole just above and slightly to the rear of the rear turn signal mounting holes in the rear frame support rails, and thats where the grab bar will bolt to. You may need some spacers and such, but should be able to bolt it up. If not directly, with some additional simple brackets would be easy to add!
          • mro
            • Oct 2005
            • 4276
            The rear mount for "grab bar"/turn signals are different between special/standard.
            On special it's higher and a tad forward and the distance between each side is narrower.
            Could make a bracket to make up differences...
            but would test it throughly. Someone hanging on to it would have a very unpleasant surprise should it come loose while on the road.
            mro
