Is this the 1196cc kit. just making sure before I buy it....ebay # 300064681658.....
wiseco
Yes - it is. K1196 is the right kit number and the 1196 is 3mm overbore where as the 1179 is only 2.5mm overbore.
It's a hair cheaper through Pro-Flo, but I'm still waiting on my kit 3 weeks later...1979 XS11F Standard - Maya - 1196cc (out of order)
http://www.livejournal.com/~xs11 -
hair cheap
I sent an offer of 350 bucks...wish me luck....p.s. I sent another set of buttons off. I told the guy to check here on the site for install instructions ALA SNOW!.....chopMDRNF
79F.....Not Stock
80G......Not Stock Either....In the worksComment
I need to re-upload some of the pictures as they apparently didn't make it in one piece...but I have a page mostly up about 'em:
I'll post the link in my evaluation once the page is finished.1979 XS11F Standard - Maya - 1196cc (out of order)
http://www.livejournal.com/~xs11Comment
That sounds about right - I had to pay tax, but I live in Florida. But keep in mind there is apparently a decent lead time - I remember it being almost as long the first time I got the kit.1979 XS11F Standard - Maya - 1196cc (out of order)
Hmm...I think I posted pics, comments last time I did mine... don't see them now though.
I'll be sure to take lots of pics this time with my digicam as I did with the bottom end.
Basically, IIRC, you just follow the manual's instructions and making sure to check/adjust ring endgap. Only the top end has to come apart - the bottom end can stay in one piece for the job.
Just pop the cams (making sure to secure the cam chain), pop the head off, pull the cylinders off (don't break 'em like I tend to do!), have cylinders bored/honed, clean all old gaskets off, prep surfaces, remove wrist pin c-clips, slide out wrist pins, pull off pistons, apply lube to new wrist pins, install pistons and wrist pins, install c-clips, check ring end-gap, put rings on in proper orientation, lubricate cylinders/pistons liberally, turn crank over until #2 and #3 pistons are up and #1 and #4 are down, and put the cylinders on #2 and #3. Push cylinders down and insert #1 and #4. If you can't get them to go in using just your fingers to compress the rings, something is wrong.
Then install head, install cams, set cam timing, install cam cover. Don't forget the gaskets
thanks again
This will be the first time I jacked with pistons and rings....I'm sure I will get plenty help here from the experienced xs'ers....I am doing this to an 80 motor with only 6900 mi....MDRNF
79F.....Not Stock
Honestly, the hardest part for me last time was setting the cams...I'm always scared I'll bugger up my valves.
Oh...and the other hard part was because I didn't set end gap...very big mistake btw...1979 XS11F Standard - Maya - 1196cc (out of order)
It's a bit steep - I'm paying $180, payed $140 a couple years ago for the same job.1979 XS11F Standard - Maya - 1196cc (out of order)
I just payed $160 for mine to be bored.Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
"No one is totally useless. They can always be used as a bad example"Comment
