i just had a thought and since i'm going to swap out coils and for anyone wanting to change out the stock wire and can't find solid core yellow accell wire like me, i went everywhere here in los angeles...
i had an apephavy, why don't i just slip some hose over some cheap and very easy to get 7mm black sold core and get the same results, so my question is instead of buying a kit for 26.00 retail or 18.00 ebay i would have way to much left over. 26 feet of varying dia.
does anyone have a few feet of yellow, i'd be glad to make a donation to the site or i could get the bulk and reverse the process, any takers?
SO....I took the remaining O-ring, and cut it in half. The securing caps fit easier with the half as long/thick O-ring. I applied clear silicone RTV all around the outside of the mounting caps/wires at the coil to better seal them from water! I also used some of this special COPPER contact grease/sealant that Randy gave out at a Rally to ensure good contacts with the plug wire and the coil and plug caps where they screw onto.
