1st gear guru question
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    I don't have an extra 1st gear to look at right now. Need to know how many teeth are there, possibly diameter too.....
    MDRNF
    79F.....Not Stock
  • Lamric
    XStremely XSive(Deceased)
    • 410
    • Kenley, Surrey, England
    First gear wheel ( 2H7-17211-00-00 ) has 38 teeth. Dunno about diameter though.
    Brian
    XS1100 LG "Mr T", SG "ICBM" & FJ1200
    Check out the XS Part Number Finder
    Be not stingy in what costs nothing as courtesy, counsel and countenance.
    • xschop
      • Feb 2006
      • 1794
      • oklahoma city
      teeth
      So. my next and maybe last question is, If I want to increase the ratio of first gear, would I want that wheel diameter to go larger or smaller in the XS11?
      MDRNF
      79F.....Not Stock
      • midnight1980
        • Mar 2007
        • 312
        • cedar city, utah
        Re: teeth
        too be quicker off the line,
        it would be a larger gear
        Gears work exactly like levers. A small gear driving a larger one gives an increase in torque, and a decrease in speed, and vise-versa.
        http://www.innerauto.com/Automotive_Systems/Front_Wheel_Drive_Transmission/1st_Gear/
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          1st gear ratio
          so what is the xs11's 1st gear ratio?
          MDRNF
          79F.....Not Stock
          • midnight1980
            • Mar 2007
            • 312
            • cedar city, utah
            Re: 1st gear ratio
            According to the Yamaha shop manual the overall 1st. gear ratio in the 850 Special was 10.79 vs 12.07 for the XS Eleven and 5th.
            • xschop
              • Feb 2006
              • 1794
              • oklahoma city
              ratios
              all the older writeups and some people are confusing on gear ratios....OVERALL and individual (1st gear) ratios I believe are getting lost in the translation. I just looked at some specs for a XS750D and the 1st gear ratio stated 13.0....I cannot find a fiche on this model. If i can get ahold of a taller (bigger gear diameter, I will mod it to go in the xs11 tranny(if need be)....
              MDRNF
              79F.....Not Stock
              • xschop
                • Feb 2006
                • 1794
                • oklahoma city
                main shaft
                to be clear, the main shaft teeth drive the 1 gear wheel? someone chime in please.....
                MDRNF
                79F.....Not Stock
