Motor Turns Over Very Slow!
  • xs11bobber
    • Jun 2009
    • 229
    • Cromwell, Indiana
    haha, the 2.5 year slow cranking forum...
    Yeah, thanks for updating that. Tell me I don't know how to search 'em, lol.
    So you say the cable was just corroded some inside the coating. That would make some sense, but when I stripped mine back it looked fairly new. I crimped on new ends. I thought I had it grounded well... for sakes of electrical testing I have everything on the right side of the bike (ie. battery resting on right peg and brake lever grounded to stator cover). Hmmmm....
    Josh Yoquelet -- I'm having dreams of my XS
    '79 XS11SF "stock"- 4/1 Kerker, T.C.'s fuse block
    '79 XS11SF "bobber"- Rotted in a pine tree for 10 years
    '81 Air forks w/23,000 miles
    New steering head races and bearings
    '78/'79 standard wire harness
    Drag bars, w/Mikes controls
    T.C.'s fuse block
    PNM Coils
    7mm Dyna Wires
    NGK Resistor Caps
    Custom 1" clutch and 9/16" MC
    http://xs11bobber.tripod.com
    • Axel
      • May 2007
      • 869
      • Renfrew,Ontario
      I'm in the process of making new battery cables . Also thinking about the extra ground cable to the starter after reading a thread of Randy's :
      I could only find the solder type cable ends so I hope they work out . The PO had used these as well but there were over-sized and he crimped them on and they were pretty loose . I cleaned up the frame point where the negative battery cable attaches and cleaned the battery posts with baking soda and a wire brush . After I coated them with vaseline (still havent got any copper anti-seize).
      XJ1100K
      Avon rubber
      MikesXS black coils
      Iridium plugs w/ 1k caps
      MikesXS front master
      Loud Horns (Stebel/Fiamm)
      Progressive fork springs
      CIBIE headlight reflector
      YICS Eliminator
