anyone flying a sidecar?
  • XSRIK
    • Jun 2006
    • 45
    • meeker colorado
    Greetings all!
    thanks for all info on the carbs. I should be on the road by Saturday! Sunday at the very latest Rocky Mountain weather permitting.
    I was wondering if anyone on the list was riding an XS with a sidecar attached?
    Due to two decades of ongoing spinal trouble this may be my next accessory. Any info appreciated! and thanks for a great site!
    Regards,
    Rik
    "Jammin'Econo"
    79 XS1100F "Talkin' 'bout shaft"
    77 CB750 A "Dumpster classic" aka "Rattus Ottomaticus"
  • randy
    • Dec 2003
    • 4521
    Rik,
    I used to run a Velorex 562 on my '81 XS1100SH it was a blast for passengers and cargo, but it was a scary bitch to drive. Sold it a year later.
      Yeah, me - -
      - - and Jetmech Marty for sure and doubtless some others.
      I'm hauling a Spirit of America chair (looks like a California Friendship I but it has a better chassis)
      A sidecar attaches to an XS11 without using the elaborate subframe that some other bikes need. Simply make sure both of the front attachments bridge both frame tubes. An L-shaped thingie bolted to both centrestand brackets and supported from the footpeg will mount the lower rear while the upper rear will be OK with a George clamp on the seat tube near the top of the shock.
      An XS11 has the power to haul any sidecar but don't fit one that's too light.
      A sidecar should weigh AT LEAST 30% of the bike's weight. Also, the wider the track is set the more stable the rig will be.
      With the stock steering trail a rig will be a touch heavy to steer. You can live with it but mix'n'matching Special fork legs onto your Standard trees (sorry, you hafta take 'em dopey ATE style brakes & all) will cut the trail in half to lighten the steering.
      Swapping in a Special 16" rear wheel will improve the final drive ratio.
      Sidecars steer all funny, take a sidecar riding course if you can find one. Do low speed figure 8s in a deserted carpark until you can controllably lift the sidecar wheel and put it down again.
      WARNING!
      Sidecars are severely addictive and there is no known cure.
      Fred Hill, S'toon.
      • AlanB
        • Oct 2006
        • 705
        • Scotland
        Hi Guys,
        The European Sport models have the leading axle forks, without the goofy brakes; Same caliper mounts as the rest!
        AlanB
        If it ain't broke, modify it!
        • fly
          • 78
          i have a 78 xs with a 93 Hitchhiker. switched to 16" rear wheel. will do the front end when it warms up.
          fly
