Had my bike for about a year now and have done nothing to the front forks. How do I know if there is even oil in them? Is it really springy if there is none? Bike sat for 10 years, should I change the seals and put in new oil? is there a way to measure the oil inside if there is any? I really know nothing about front forks. any and all help will be greatly appreciated. Thanks
front fork question
front fork question
79 XS1100 modified standard
straight pipe 4-2 exhaust
Owned 83 Honda V65 Magna
Owned 02 Vstar 650 classic
owned 85 Honda Shadow VT 700CTags: None -
Pull the drain plugs and see how much oil comes out and I'll bet it will be black. It will be springy if there isn't enough oil to dampen the springs. According to my Clymers, regular forks take 7.12 oz, and air/forks take 7.61 oz. The book says to use a 10w fork oil. -
Hi Audijunky,
If it is 10 years old, it needs changed! If they are not leaking, I would leave the seals alone. There are drain screws on the outside of the lags, near the bottom. Take them out and let it drain; you will have to pump the forks up and down to get the last of it out- It will spray out horizontally, so make arrangements to catch it!
Refill by taking the top caps out- one at a time. Your manual will give quantities and grades; try standard first, then upgrade if necessary!
I have been meaning to ask for ages; Why are you called Audijunky?
AlanBIf it ain't broke, modify it!Comment
I like Audi's and I currently drive a 2000 AWD Avant wagon. I like German cars for some reason. I also have A 94 VW golf and I am 27 years old.
So if I open the drain plugs and nothing comes out, should I first add oil and check for leaks or just get new seals than add oil ?
Just noticed your from Scotland, not sure if you know or not but a junky is slang in the US for someone who is addicted to something(drugs, speed, adrenaline, cars, whatever)Last edited by audijunky; 03-09-2007, 09:58 AM."Beware of any man that owns a pig farm"
owned 85 Honda Shadow VT 700CComment
Hi Audijunky,
Same word works over here too! I wondered 'cos I am one too. I drive a 200 Turbo quattro Avant and have two saloons for spares. I have just bought an A2 TDi for the wife; don't know if they got exported to USA?
Hi Audijunky,
Sorry, I got sidetracked! Forks are unlikely to be empty- bike would be almost undriveable. If nothing comes out, they are probablt blocked with muck. either try a bit of wire, or just bounce the forks with the plugs out.
If the forks are empty, the forks will continue to bounce once you have them started.
Well I guess there is oil in them cause I have been riding it. They are not springy at all kind of saggy actually. I ask cause I have lowered it considerably and need more stiffness.If I hit a cornerer to fast and try to break a little while cornering it drags the header to pipe connecting hardware. Not sure about the TDI.
actually I dont think they sell any A2's here. I have never seen one anyway. Just A4, A6, A8 S4 S6 and maybe the S8. They sure are some nice rides."Beware of any man that owns a pig farm"
Oh yeah, guess I am gonna just do the oil change. What would putting more oil in than the specs say do? Stiffen it up? I wish it were that easy"Beware of any man that owns a pig farm"
What Alan really means is if you pump the forks aggressively, it will spray nasty black oil about six feet onto something you didn't really want to get dirty.Originally posted by AlanB
AlanB
DAMHIKIJD...
Ken TalbotComment
