Exhaust Gasket Fitment
  • larrydreed
    • 19
    • Crossville, Tennessee
    I bought new gaskets for the '79 hybrid. They appear to be thin stainless or aluminum designed to crush when fitted. The problem I have is the studs are too short to get the flange nuts started. Anyone else have this problem with the stock exhaust gaskets? Solutions?
    Larry/Crossville, TN
    80 XS11 Midnight (el gallo negro)
    80 XS850S
    79 XS750S
    79 XS650
    77 RD400
    80 SR500
    et al
    The studs are two lengths, depending on the model of bike. I think the Standard has the longer stud, and the special had the shorter studs.
    You can try and replace the studs with a longer one if you have a special, but I would run a tap through the head if you do. Also, use RED locktight on the studs, to keep them from backing out.
    • Jerry
      XS & TRUE XJ GURU
      • 3023
      • Elma, IA.
      Make sure all the old gasket material is removed. Sounds obvious, but I've seen cases where the outer ring of the old gasket looks for all the world like part of the head. If not removed the new gaskets don't seat all the way down like they should. There should be a well-defined shoulder that the new gaskets seat against.
      You are right, the gaskets are designed to crush when fitted, which means you should check the flange nuts fairly often for the first couple hundred miles after you get them installed; they will need to be snugged up once or twice.
      Jerry Fields
      '82 XJ 'Sojourn'
      '06 Concours
      My Galleries Page.
      My Blog Page.
      • prometheus578
        XS-XJ Super Guru (RESIGNED)
        • Aug 2004
        • 4012
        • Olympia , Wa.
        "Ray's a real stud!" Woo Woo!
        I agree with the loctite, though I would use blue. Will still hold it in place... but I may wish to take them out at a later date. (actually, I wouldn't use any at all, but that's just me)
        And the loctite goes on the part of the stud that goes into the head only, not the nuts that hold the headers on.
          I have a 78 engine in my 81 SH, and that engine has longer studs than those that were in the original 81 engine. I had to use a few washers to take up the extra length.
